Ir para o conteúdo principal
Introdução
This guide will thoroughly explain how to easily repair a zipper that is broken. No special requirements needed; just needle-nose pliers, scissors, and a needle and thread!
  1. Take the needle nose pliers and remove the metal or plastic stopper at the end of the zipper. Zip the zipper all the way down to the last set of teeth. Zip the zipper all the way down to the last set of teeth.
    • Take the needle nose pliers and remove the metal or plastic stopper at the end of the zipper.
    • Zip the zipper all the way down to the last set of teeth.
  2. Align both sides of the zipper evenly and slip the zipper back on track. Align both sides of the zipper evenly and slip the zipper back on track. Align both sides of the zipper evenly and slip the zipper back on track.
    • Align both sides of the zipper evenly and slip the zipper back on track.
  3. Start zipping up the zipper to make sure it has been aligned properly. Start zipping up the zipper to make sure it has been aligned properly. Start zipping up the zipper to make sure it has been aligned properly.
    • Start zipping up the zipper to make sure it has been aligned properly.
  4. Thread the needle. Sew up the area where the metal or plastic stopper used to reside. Sew up the area where the metal or plastic stopper used to reside.
    • Thread the needle.
    • Sew up the area where the metal or plastic stopper used to reside.
  5. Tie off what has been sewn by making a knot in the thread. Tie off what has been sewn by making a knot in the thread. Tie off what has been sewn by making a knot in the thread.
    • Tie off what has been sewn by making a knot in the thread.
  6. Take the scissors and cut off the access thread. Get as close to the knot as you can without cutting it off. Take the scissors and cut off the access thread. Get as close to the knot as you can without cutting it off.
    • Take the scissors and cut off the access thread. Get as close to the knot as you can without cutting it off.
  7. Zip up the garmet to make sure everything is working properly. Zip up the garmet to make sure everything is working properly. Zip up the garmet to make sure everything is working properly.
    • Zip up the garmet to make sure everything is working properly.
Conclusão
9 outras pessoas concluíram este guia.
Not helpful. Suppose if the slider part broke and is now now. Now what?
Walter Nagel - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 12
Últimos 30 dias: 38
Duração total: 2,469
