Ir para o conteúdo principal
How to Fix a Broken Vertical Blind for Sliding Glass Door
O que você precisa
  1. How to Fix a Broken Vertical Blind for Sliding Glass Door, How to Fix a Broken Vertical Blind for Sliding Glass Door: passo 1, imagem 1 %32 How to Fix a Broken Vertical Blind for Sliding Glass Door, How to Fix a Broken Vertical Blind for Sliding Glass Door: passo 1, imagem 2 %32
    • Remove the broken hanging blind slat from the holding piece at the top of the blind.
    • In this case, it was clear the slat was broken because there was tape needed to hold it on.
  2. How to Fix a Broken Vertical Blind for Sliding Glass Door: passo 2, imagem 1 %32 How to Fix a Broken Vertical Blind for Sliding Glass Door: passo 2, imagem 2 %32
    • Use scissors and cut the end of the slat just beneath the hole so it looks neater and a new hole can be made beneath it.
  3. How to Fix a Broken Vertical Blind for Sliding Glass Door: passo 3, imagem 1 %32 How to Fix a Broken Vertical Blind for Sliding Glass Door: passo 3, imagem 2 %32
    • Use a ruler and pencil and mark halfway in between the two long sides.
    • In this case, the mark was made at 1.75 inches from each side.
  4. How to Fix a Broken Vertical Blind for Sliding Glass Door: passo 4, imagem 1 %32 How to Fix a Broken Vertical Blind for Sliding Glass Door: passo 4, imagem 2 %32
    • Use the ruler and pencil again, and go along the center line, down about 3/8 inch and put a dot.
    • In this particular case, about 3/8 inches works best however it could vary depending on the blinds.
  5. How to Fix a Broken Vertical Blind for Sliding Glass Door: passo 5, imagem 1 %32 How to Fix a Broken Vertical Blind for Sliding Glass Door: passo 5, imagem 2 %32
    • Use the hole puncher and make a hole through the dot you just made on the blind slat.
  6. How to Fix a Broken Vertical Blind for Sliding Glass Door: passo 6, imagem 1 %32 How to Fix a Broken Vertical Blind for Sliding Glass Door: passo 6, imagem 2 %32
    • Replace the hanging slat back into the holding piece on the blinds.
    • Be careful in this step once again so as to not break the plastic piece or the newly fixed blind slat once again.
Conclusão
Your vertical blinds are now fixed and hanging properly, looking brand new!
Andrew Sheedy
Membro desde: 03/22/21
173 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 36
Últimos 30 dias: 160
Duração total: 6,655
