Ir para o conteúdo principal
How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses
O que você precisa
  1. How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses, How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: passo 1, imagem 1 %32 How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses, How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: passo 1, imagem 2 %32 How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses, How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: passo 1, imagem 3 %32
    • Apply dish soap to the broken temple arm sections.
    • Scrub the broken temple arm sections with the dish soap for one minute.
  2. How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: passo 2, imagem 1 %32 How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: passo 2, imagem 2 %32 How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: passo 2, imagem 3 %32
    • Rinse the dish soap off of the temple arm sections with water.
    • Dry off the temple arm sections with a paper towel.
  3. How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: passo 3, imagem 1 %32 How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: passo 3, imagem 2 %32
  4. How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: passo 4, imagem 1 %32 How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: passo 4, imagem 2 %32 How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: passo 4, imagem 3 %32
    • Use the coated toothpick to apply a thin layer of Gorilla Super Glue to one of the broken temple arm sections.
    • Gorilla Super Glue works better when less of the product is applied. Make sure to only apply a thin layer of glue to the broken temple arm section.
  5. How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: passo 5, imagem 1 %32 How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: passo 5, imagem 2 %32
    • Press the two temple arm sections together and hold for one minute.
    • Caution: Gorilla Super Glue can remain on your skin for up to a week. Place hands away from the glue applied when holding the temple sections together to keep hands clean.
  6. How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: passo 6, imagem 1 %32 How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: passo 6, imagem 2 %32 How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: passo 6, imagem 3 %32
    • Tightly wrap masking tape around the area where you placed the temple arm sections together.
    • Leave the masking tape on for five minutes.
  7. How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: passo 7, imagem 1 %32 How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: passo 7, imagem 2 %32
    • Remove the masking tape.
  8. How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: passo 8, imagem 1 %32 How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: passo 8, imagem 2 %32 How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: passo 8, imagem 3 %32
    • Select a 1/4" heat-shrinking tube.
    • Slide the tube to the area where you applied the Gorilla Super Glue.
  9. How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: passo 9, imagem 1 %32 How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: passo 9, imagem 2 %32 How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: passo 9, imagem 3 %32
    • Plug in a handheld hair dryer.
    • Turn the handheld hair dryer to the highest heat setting.
  10. How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: passo 10, imagem 1 %32 How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: passo 10, imagem 2 %32 How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: passo 10, imagem 3 %32
    • Circulate the handheld hair dryer around the heat-shrinking tube until it is suctioned around the temple arm.
    • Caution: Keep your fingers away from the area you are aiming the hair dryer. The hair dryer produces high levels of heat that can irritate or burn a person's skin.
Linha de Chegada
Maia Michelle Brown
Membro desde: 02/20/24
181 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 9
Últimos 30 dias: 33
Duração total: 111
