Ir para o conteúdo principal
How to Fix a Broken Strap on a Strapback Hat
O que você precisa
  1. How to Fix a Broken Strap on a Strapback Hat, How to Fix a Broken Strap on a Strapback Hat: passo 1, imagem 1 %32 How to Fix a Broken Strap on a Strapback Hat, How to Fix a Broken Strap on a Strapback Hat: passo 1, imagem 2 %32 How to Fix a Broken Strap on a Strapback Hat, How to Fix a Broken Strap on a Strapback Hat: passo 1, imagem 3 %32
    • Measure the thread.
    • We recommend an arms-length amount of thread to ensure its enough to complete the fix without needing more thread.
    • Cut the thread at desired length.
  2. How to Fix a Broken Strap on a Strapback Hat: passo 2, imagem 1 %32 How to Fix a Broken Strap on a Strapback Hat: passo 2, imagem 2 %32
    • Thread the needle.
  3. How to Fix a Broken Strap on a Strapback Hat: passo 3, imagem 1 %32 How to Fix a Broken Strap on a Strapback Hat: passo 3, imagem 2 %32
    • Pull the thread through the needle until both ends of the thread meet.
    • Tie a knot at the end of the thread.
  4. How to Fix a Broken Strap on a Strapback Hat: passo 4, imagem 1 %32 How to Fix a Broken Strap on a Strapback Hat: passo 4, imagem 2 %32
    • Position the strap to where it was originally located on the hat.
  5. How to Fix a Broken Strap on a Strapback Hat: passo 5, imagem 1 %32 How to Fix a Broken Strap on a Strapback Hat: passo 5, imagem 2 %32
    • Ensure that the strap doesn't move by using a binder clip to hold it in place.
  6. How to Fix a Broken Strap on a Strapback Hat: passo 6, imagem 1 %32 How to Fix a Broken Strap on a Strapback Hat: passo 6, imagem 2 %32 How to Fix a Broken Strap on a Strapback Hat: passo 6, imagem 3 %32
    • Starting on the inside of the hat, poke the needle through the cap and loose strap.
    • Pull the needle through the fabric and out the other end.
  7. How to Fix a Broken Strap on a Strapback Hat: passo 7, imagem 1 %32 How to Fix a Broken Strap on a Strapback Hat: passo 7, imagem 2 %32
    • Move the needle a few millimeters to the left and poke the needle through the front of the hat.
    • Pull the needle out on the other end.
  8. How to Fix a Broken Strap on a Strapback Hat: passo 8, imagem 1 %32 How to Fix a Broken Strap on a Strapback Hat: passo 8, imagem 2 %32
    • Repeat steps 6 and 7 until the strap is fully sewn onto the hat.
  9. How to Fix a Broken Strap on a Strapback Hat: passo 9, imagem 1 %32 How to Fix a Broken Strap on a Strapback Hat: passo 9, imagem 2 %32 How to Fix a Broken Strap on a Strapback Hat: passo 9, imagem 3 %32
    • Tie a knot as close to the base of the hat as possible and cut the thread.
  10. How to Fix a Broken Strap on a Strapback Hat: passo 10, imagem 1 %32
    • Your hat is fixed and ready to wear!
Conclusão
Congratulations! With some simple hand sewing, you were able to fix the broken strap on your hat.
4 outras pessoas executaram este guia.
Sarah Sy
Membro desde: 02/02/23
265 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team 1-1, Andersen Winter 2023 Membro de UC Davis, Team 1-1, Andersen Winter 2023
UCD-ANDERSEN-W23S1G1
3 Membros
Autoria de 4 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 27
Últimos 7 dias: 119
Últimos 30 dias: 449
Ao todo: 10,169
