Ir para o conteúdo principal
How to Fix a Broken Seam in a Camping Chair
O que você precisa
  1. How to Fix a Broken Seam in a Camping Chair, Identify the repair area: passo 1, imagem 1 %32 How to Fix a Broken Seam in a Camping Chair, Identify the repair area: passo 1, imagem 2 %32 How to Fix a Broken Seam in a Camping Chair, Identify the repair area: passo 1, imagem 3 %32
    • Locate the broken seam that needs to be fixed.
  2. How to Fix a Broken Seam in a Camping Chair, Unscrew the back of the chair: passo 2, imagem 1 %32 How to Fix a Broken Seam in a Camping Chair, Unscrew the back of the chair: passo 2, imagem 2 %32 How to Fix a Broken Seam in a Camping Chair, Unscrew the back of the chair: passo 2, imagem 3 %32
    • Use a screwdriver to disassemble the back support and set aside the screws and remaining parts.
  3. How to Fix a Broken Seam in a Camping Chair, Clean the area: passo 3, imagem 1 %32 How to Fix a Broken Seam in a Camping Chair, Clean the area: passo 3, imagem 2 %32 How to Fix a Broken Seam in a Camping Chair, Clean the area: passo 3, imagem 3 %32
    • Using a pair of scissors and a "seam ripper" remove the loose threads.
  4. How to Fix a Broken Seam in a Camping Chair, Start sewing: passo 4, imagem 1 %32 How to Fix a Broken Seam in a Camping Chair, Start sewing: passo 4, imagem 2 %32 How to Fix a Broken Seam in a Camping Chair, Start sewing: passo 4, imagem 3 %32
    • Sew along the "dotted line" following the direction of the red arrow. This is the path where the previous stitch used to be.
    • Note: in this example, the original seam used to have 2 lines of stitches, this is why a second line of stitches is needed to reinforce the area.
  5. How to Fix a Broken Seam in a Camping Chair, Clean the loose threads: passo 5, imagem 1 %32 How to Fix a Broken Seam in a Camping Chair, Clean the loose threads: passo 5, imagem 2 %32
    • Using a pair of scissors cut the remaining threads to clean the area.
  6. How to Fix a Broken Seam in a Camping Chair, Reassemble the chair: passo 6, imagem 1 %32 How to Fix a Broken Seam in a Camping Chair, Reassemble the chair: passo 6, imagem 2 %32 How to Fix a Broken Seam in a Camping Chair, Reassemble the chair: passo 6, imagem 3 %32
    • Start by putting the components back, first the repaired fabric and then the rest of the parts.
    • Tip: make sure the holes in the metal part of the chair match the holes of the fabric (orange circles).
    • Screw back the pieces that were taken on the previous steps.
  7. How to Fix a Broken Seam in a Camping Chair, Finished and ready!: passo 7, imagem 1 %32 How to Fix a Broken Seam in a Camping Chair, Finished and ready!: passo 7, imagem 2 %32
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
Conclusão
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
Ben Blischke
Membro desde: 07/19/23
9.298 Reputação
Autoria de 62 guias
Equipe
INTERSPORT Membro de INTERSPORT
Community
Membros da 22
Autoria de 161 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 29
Duração total: 167
