Ir para o conteúdo principal
How to Fix a Broken Loop in a Backpack
O que você precisa
  1. How to Fix a Broken Loop in a Backpack, Locate the repair area: passo 1, imagem 1 %32 How to Fix a Broken Loop in a Backpack, Locate the repair area: passo 1, imagem 2 %32
    • Identify the loop that needs to be repaired.
  2. How to Fix a Broken Loop in a Backpack, Clean the area: passo 2, imagem 1 %32 How to Fix a Broken Loop in a Backpack, Clean the area: passo 2, imagem 2 %32
    • Use a seam ripper and a pair of scissors to completely remove the loop and get rid of any loose thread.
    • Tip: Once you have removed the loop, make sure you leave a space in the seam area to reinsert it later.
  3. How to Fix a Broken Loop in a Backpack, Start stitching: passo 3, imagem 1 %32 How to Fix a Broken Loop in a Backpack, Start stitching: passo 3, imagem 2 %32 How to Fix a Broken Loop in a Backpack, Start stitching: passo 3, imagem 3 %32
    • Once you have removed the broken loop, stitch both ends together using a sewing machine.
  4. How to Fix a Broken Loop in a Backpack, Set the loop in place: passo 4, imagem 1 %32 How to Fix a Broken Loop in a Backpack, Set the loop in place: passo 4, imagem 2 %32 How to Fix a Broken Loop in a Backpack, Set the loop in place: passo 4, imagem 3 %32
    • Introduce the stitched loop into the seam hole and hold it together with both hands.
  5. How to Fix a Broken Loop in a Backpack, Stitch the loop in place: passo 5, imagem 1 %32 How to Fix a Broken Loop in a Backpack, Stitch the loop in place: passo 5, imagem 2 %32 How to Fix a Broken Loop in a Backpack, Stitch the loop in place: passo 5, imagem 3 %32
    • Following the last step, keep holding together the loop with both hands and gently place it on the sewing machine and start stitching.
    • Use a pair of scissors to clean the area and cut any loose threads.
  6. How to Fix a Broken Loop in a Backpack, Finished and ready!: passo 6, imagem 1 %32 How to Fix a Broken Loop in a Backpack, Finished and ready!: passo 6, imagem 2 %32 How to Fix a Broken Loop in a Backpack, Finished and ready!: passo 6, imagem 3 %32
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
Conclusão
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
Ben Blischke
Membro desde: 07/19/23
9.298 Reputação
Autoria de 62 guias
Equipe
INTERSPORT Membro de INTERSPORT
Community
Membros da 22
Autoria de 161 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 16
Duração total: 72
