Ir para o conteúdo principal
How to Fix a Broken High Heel
O que você precisa
  1. How to Fix a Broken High Heel, How to Fix a Broken High Heel: passo 1, imagem 1 %32 How to Fix a Broken High Heel, How to Fix a Broken High Heel: passo 1, imagem 2 %32
    • Peel back the sole of the heel.
    • This first step is if your heel has not completely broken off yet.
    • If it has broken off cleanly, proceed to Step 5.
  2. How to Fix a Broken High Heel: passo 2, imagem 1 %32 How to Fix a Broken High Heel: passo 2, imagem 2 %32
    • Remove the largest 10 x 1/2-inch stainless screw in the middle of the heel with a screwdriver.
  3. How to Fix a Broken High Heel: passo 3, imagem 1 %32
    • Once the heel is broken off, use pliers to remove the four smaller 30 mm long, dia. 1.5 mm nails on the heel.
    • It’s alright if they bend and break. That is why we recommend buying extra nails.
  4. How to Fix a Broken High Heel: passo 4, imagem 1 %32
    • Sand the heel down after removal of all the nails.
    • This will make the surface smoother for reattachment.
  5. How to Fix a Broken High Heel: passo 5, imagem 1 %32
    • Align the heel back in place.
    • Use a hammer to reinsert the four smaller 30 mm long, dia. 1.5 mm nails.
  6. How to Fix a Broken High Heel: passo 6, imagem 1 %32
    • Use a screwdriver to reinsert the largest middle 10 x 1/2" stainless steel screw into the heel.
  7. How to Fix a Broken High Heel: passo 7, imagem 1 %32 How to Fix a Broken High Heel: passo 7, imagem 2 %32
    • Now that the nails are all in place and the heel is secure, use leather repair glue to glue back the sole.
  8. How to Fix a Broken High Heel: passo 8, imagem 1 %32 How to Fix a Broken High Heel: passo 8, imagem 2 %32
    • Find any heavy object in your home, and lay it on top of the sole to make sure the glue settles.
Conclusão
That concludes our guide we hope you have found this helpful.
Cindy Tan
Membro desde: 02/03/23
157 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team 1-2, Andersen Winter 2023 Membro de UC Davis, Team 1-2, Andersen Winter 2023
UCD-ANDERSEN-W23S1G2
Membros da 2
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 14
Últimos 30 dias: 52
Duração total: 590
