Ir para o conteúdo principal
How to Fix a Broken Ceramic Vase
O que você precisa
  1. How to Fix a Broken Ceramic Vase, How to Fix a Broken Ceramic Vase: passo 1, imagem 1 %32
    • Examine the damage to the vase. Determine how large the cracks and chips are.
    • Smaller cracks can be fixed with a ceramic adhesive, while larger cracks may require putty.
  2. How to Fix a Broken Ceramic Vase: passo 2, imagem 1 %32
    • Sand the broken edges and cracked pieces on the vase with a sander block.
  3. How to Fix a Broken Ceramic Vase: passo 3, imagem 1 %32 How to Fix a Broken Ceramic Vase: passo 3, imagem 2 %32
    • Apply ceramic adhesive to the broken pieces and press them together for two minutes.
  4. How to Fix a Broken Ceramic Vase: passo 4, imagem 1 %32
    • Secure masking tape over the cracks and let the vase dry for 3 hours.
  5. How to Fix a Broken Ceramic Vase: passo 5, imagem 1 %32
    • After the vase dries, clean the areas with a cloth where chunks of ceramic are missing.
  6. How to Fix a Broken Ceramic Vase: passo 6, imagem 1 %32 How to Fix a Broken Ceramic Vase: passo 6, imagem 2 %32
    • Use a chisel scraper to fill in the missing areas with putty and allow it to dry completely.
  7. How to Fix a Broken Ceramic Vase: passo 7, imagem 1 %32
    • Select a paint that matches the vase and use a soft paintbrush to paint the dry putty wall.
  8. How to Fix a Broken Ceramic Vase: passo 8, imagem 1 %32
    • Let the paint dry for one hour on the vase and your repair is finished.
Linha de Chegada
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 7
Últimos 7 dias: 42
Últimos 30 dias: 175
Duração total: 2,925
