Ir para o conteúdo principal
How to Fix a BIC Wite-Out Mini
O que você precisa
  1. How to Fix a BIC Wite-Out Mini, How to Fix a BIC Wite-Out Mini: passo 1, imagem 1 %32
    • Place the dispenser component with the logo facing down, with other components laid out on a clean, flat surface.
  2. How to Fix a BIC Wite-Out Mini: passo 2, imagem 1 %32
    • Stabilize the small gear with tweezers to prevent further unwinding.
  3. How to Fix a BIC Wite-Out Mini: passo 3, imagem 1 %32 How to Fix a BIC Wite-Out Mini: passo 3, imagem 2 %32 How to Fix a BIC Wite-Out Mini: passo 3, imagem 3 %32
    • Untangle the plastic strip by rotating the large gear in a circular motion, going in the opposite direction of the spiral.
    • Stop once the plastic strip connecting the gears is straight.
  4. How to Fix a BIC Wite-Out Mini: passo 4, imagem 1 %32 How to Fix a BIC Wite-Out Mini: passo 4, imagem 2 %32 How to Fix a BIC Wite-Out Mini: passo 4, imagem 3 %32
    • Feed the plastic strip into the small gear until the white-out strip is visible.
    • Turn the big gear toward the small gear until they are close to each other.
  5. How to Fix a BIC Wite-Out Mini: passo 5, imagem 1 %32
    • Place gears back into dispenser component with the logo.
    • Place the small gear onto the module closer to the dispensing slot.
    • Place the large gear onto module farthest from the dispensing slot.
  6. How to Fix a BIC Wite-Out Mini: passo 6, imagem 1 %32
    • Hold the white-out strip with tweezers and pull to wrap the strip around the dispensing slot.
    • Make sure to stabilize the gears.
  7. How to Fix a BIC Wite-Out Mini: passo 7, imagem 1 %32 How to Fix a BIC Wite-Out Mini: passo 7, imagem 2 %32 How to Fix a BIC Wite-Out Mini: passo 7, imagem 3 %32
    • Wrap the black band around both gears.
    • If necessary, stabilize the large gear with tweezers.
    • Wrap the band starting from large gear to small gear.
  8. How to Fix a BIC Wite-Out Mini: passo 8, imagem 1 %32 How to Fix a BIC Wite-Out Mini: passo 8, imagem 2 %32
    • Close the device until the side components click closed.
Conclusão
Congrats! You have just successfully repaired your BIC Wite-Out Mini!
Test your BIC Wite-Out Mini to make sure that it works correctly. If it does not work, repeat steps 1-8 and try again!
Lauren Miller
Membro desde: 01/31/24
157 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team 3-1, Andersen Winter 2024 Membro de UC Davis, Team 3-1, Andersen Winter 2024
UCD-ANDERSEN-W24S3G1
3 Membros
1 Guia de autoria
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 31
Últimos 30 dias: 159
Ao todo: 1,764
