Ir para o conteúdo principal
How to Fix Your Cosplay Rabbit Ears
O que você precisa
  1. How to Fix Your Cosplay Rabbit Ears, How to Fix Your Cosplay Rabbit Ears: passo 1, imagem 1 %32 How to Fix Your Cosplay Rabbit Ears, How to Fix Your Cosplay Rabbit Ears: passo 1, imagem 2 %32
    • Rip the ears off of the headband.
    • They are attached with glue, as seen in the photo.
    • Set the headband aside for now.
  2. How to Fix Your Cosplay Rabbit Ears: passo 2, imagem 1 %32 How to Fix Your Cosplay Rabbit Ears: passo 2, imagem 2 %32 How to Fix Your Cosplay Rabbit Ears: passo 2, imagem 3 %32
    • Cut a small hole into the middle backside of the ear, vertically, to remove the wired structure.
    • The hole should be 1-2 inches long.
    • Feel around on the inside of the ear until you find the black wire.
    • Pull out the wire.
    • It is not attached to anything, so it will come out easily.
  3. How to Fix Your Cosplay Rabbit Ears: passo 3, imagem 1 %32 How to Fix Your Cosplay Rabbit Ears: passo 3, imagem 2 %32 How to Fix Your Cosplay Rabbit Ears: passo 3, imagem 3 %32
    • Straighten the wire completely.
    • Double the wire by bending it in half.
    • Bend one end a couple of times over, as seen in the pictures. This end will be the bottom base of the ear.
    • Add the wire back into the fabric ear, with the thicker end at the bottom of the ear. Make sure it is centered.
  4. How to Fix Your Cosplay Rabbit Ears: passo 4, imagem 1 %32 How to Fix Your Cosplay Rabbit Ears: passo 4, imagem 2 %32
    • Thread your needle and do a simple stitch along the cut to sew up the hole from the wire.
  5. How to Fix Your Cosplay Rabbit Ears: passo 5, imagem 1 %32 How to Fix Your Cosplay Rabbit Ears: passo 5, imagem 2 %32 How to Fix Your Cosplay Rabbit Ears: passo 5, imagem 3 %32
    • When sewing down the wire, make sure that the wire is completely centered.
    • Sew a simple stitch along and down the wire, looping the needle over and under it.
  6. How to Fix Your Cosplay Rabbit Ears: passo 6, imagem 1 %32 How to Fix Your Cosplay Rabbit Ears: passo 6, imagem 2 %32
    • Measure out a small piece of white fabric.
    • The measurements should be around 1 inch by 4 inches.
    • Cut out two strips of this measurement.
  7. How to Fix Your Cosplay Rabbit Ears: passo 7, imagem 1 %32 How to Fix Your Cosplay Rabbit Ears: passo 7, imagem 2 %32 How to Fix Your Cosplay Rabbit Ears: passo 7, imagem 3 %32
    • Wrap the fabric around one side of the headband, relatively tight.
    • Sew along the headband, as seen in the pictures. You should be able to slide the fabric off of the headband afterward.
  8. How to Fix Your Cosplay Rabbit Ears: passo 8, imagem 1 %32 How to Fix Your Cosplay Rabbit Ears: passo 8, imagem 2 %32
    • Spread the two sides of the fabric strip out and place it on the base of the ear.
    • Sew each side down securely.
    • Slip the headband back into the fabric on both ears to make sure it is stable.
  9. How to Fix Your Cosplay Rabbit Ears: passo 9, imagem 1 %32 How to Fix Your Cosplay Rabbit Ears: passo 9, imagem 2 %32 How to Fix Your Cosplay Rabbit Ears: passo 9, imagem 3 %32
    • Your ears and now finished! They should stick up perfectly and be able to bend in different directions.
Conclusão
Uma outra pessoa concluiu este guia.
Um comentário
why does this exist
Ryan Sturt - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 7
Últimos 7 dias: 27
Últimos 30 dias: 60
Duração total: 841
