Ir para o conteúdo principal
How to Fix Xbox One Wireless Controller Drift
O que você precisa
  1. How to Fix Xbox One Wireless Controller Drift, How to Fix Xbox One Wireless Controller Drift: passo 1, imagem 1 %32
    • Remove the batteries from the controller.
    • If you are using a wired controller, disconnect the wire.
  2. How to Fix Xbox One Wireless Controller Drift: passo 2, imagem 1 %32 How to Fix Xbox One Wireless Controller Drift: passo 2, imagem 2 %32 How to Fix Xbox One Wireless Controller Drift: passo 2, imagem 3 %32
    • Pour 90% isopropyl alcohol on the tip of a cotton ball.
    • Keep the item away from children and avoid touching your face and open wounds while using it.
  3. How to Fix Xbox One Wireless Controller Drift: passo 3, imagem 1 %32 How to Fix Xbox One Wireless Controller Drift: passo 3, imagem 2 %32
    • Rub the cotton ball all along the edges of the thumbstick.
  4. How to Fix Xbox One Wireless Controller Drift: passo 4, imagem 1 %32
    • Let the controller dry for 40-60 seconds.
    • Repeat Steps 2-4 two more times or until the thumbstick no longer drifts.
  5. How to Fix Xbox One Wireless Controller Drift: passo 5, imagem 1 %32 How to Fix Xbox One Wireless Controller Drift: passo 5, imagem 2 %32 How to Fix Xbox One Wireless Controller Drift: passo 5, imagem 3 %32
    • Connect your controller and see if there are any drift stick problems in any game. If the issue continues, then the next best option is to replace the joystick, and if that doesn't work, it's time to buy a new controller.
Conclusão
After fixing the controller, if you run into the same problem more than a few times, the next best option I recommend would be to either replace the joystick or get an entirely new controller.
15 outras pessoas executaram este guia.
Equipe
11Comentários do guia
would hand sanitizer be a good substitute?
just me - Responder
Personally wouldn't recommend using hand sanitizer. IPA of various concentrations is already cheap and readily available in every pharmacy section, or a can of WD-40 Specialist Contact Cleaner is also around $5. In theory, hand sanitizer would "work" if it's ethanol/isopropyl alcohol based, but there's such a broad range of hand sanitizers, it would be irresponsible to make a blanket statement that they're all safe/unsafe for electronics. For example, many brands include fragrances, moisturizers, vitamin-E, etc. to keep your hands from excessively drying out, which can end up leaving residue and gumming up your electronics' contacts further.
SPARTAN VI -
I had actually been dumb enough not to look this up, so I just replaced the thumb sticks and it had made it better, but it didn't fix it. Any recommendations? I've had the controller since around 2016 or 2017. Original controller that came with the xbox.
Chill Doggo - Responder
The original Xbox one controller is notorious for getting stick drift. Only way to fix that one is the re-Solder the thumb stick back on. Like remove it and re-solder it.
Carlos Ramos -
THANK YOU!!!! Bruh….thank you.
Nick Ikombe - Responder
Comentar
Visualizações:
Últimas 24 horas: 82
Últimos 7 dias: 653
Últimos 30 dias: 2,520
Ao todo: 215,875
