Ir para o conteúdo principal
How to Fix Warped LEGO Baseplates
O que você precisa
  1. How to Fix Warped LEGO Baseplates, How to Fix Warped LEGO Baseplates: passo 1, imagem 1 %32
    • Grab a pot large enough to place the LEGO baseplate in.
    • Fill the pot full of tap water, enough to submerge the baseplate completely.
  2. How to Fix Warped LEGO Baseplates: passo 2, imagem 1 %32 How to Fix Warped LEGO Baseplates: passo 2, imagem 2 %32 How to Fix Warped LEGO Baseplates: passo 2, imagem 3 %32
    • Place the pot of water on a stove.
    • Turn the stove burner on to medium heat.
    • Heat the water to approximately 100 degrees Fahrenheit. Use a thermometer to ensure proper heat.
    • Do not heat water near or above a temperature of 140 degrees Fahrenheit to avoid damaging/melting the plastic.
  3. How to Fix Warped LEGO Baseplates: passo 3, imagem 1 %32 How to Fix Warped LEGO Baseplates: passo 3, imagem 2 %32 How to Fix Warped LEGO Baseplates: passo 3, imagem 3 %32
    • Place the LEGO baseplate in the pot of heated water for 5-7 minutes.
    • Ensure that the LEGO baseplate is fully submerged for the entire heating duration.
  4. How to Fix Warped LEGO Baseplates: passo 4, imagem 1 %32
    • Turn the stove off and remove the baseplate from the water.
    • Dry the LEGO baseplate using a paper towel.
  5. How to Fix Warped LEGO Baseplates: passo 5, imagem 1 %32
    • Quickly sandwich the baseplate between two flat baking pans while the baseplate is still warm.
    • You can use any two flat, sturdy objects if baking pans are unavailable.
  6. How to Fix Warped LEGO Baseplates: passo 6, imagem 1 %32 How to Fix Warped LEGO Baseplates: passo 6, imagem 2 %32
    • Place two plastic clamps over the two pans to evenly apply firm pressure against the baseplate.
    • If clamps are unavailable, you can use weights to apply similar pressure.
    • Leave the LEGO baseplate in between the pressure of the baking pans for at least 5 hours.
Conclusão
If your LEGO baseplate is still warped after the 5 hours of sitting in between the clamps, repeat process and leave the LEGO baseplate in between clamps for an additional 5 hours.
Nicole DeFer
Membro desde: 09/26/22
203 Reputação
Autoria de 1 guia
Equipe
CSU Fullerton, Team 1-5, Bruce Fall 2022 Membro de CSU Fullerton, Team 1-5, Bruce Fall 2022
CSUF-BRUCE-F22S1G5
Membros da 2
1 Guia de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 28
Últimos 30 dias: 118
Duração total: 1,256
