Introdução
In this guide, users will learn to repair a misaligned hole for the strike plate and door latch. Users may need to be careful of wood debris when drilling new holes or chiseling out the shape for the door latch. When selecting a drill bit, make sure that the correct size is chosen according to the size of the screws.
O que você precisa
Using your screwdriver, unscrew the top screw of the strike plate.
After unscrewing the first screw, remove the second screw as well.
Remove the strike plate.
Now that the repair is complete, check that the door latch fits into the hole and that the door is able to close properly.
3 outras pessoas executaram este guia.
