Ir para o conteúdo principal
How to Fix Stuck Williams Allegro III Piano Keys
O que você precisa
  1. How to Fix Stuck Williams Allegro III Piano Keys, How to Fix Stuck Williams Allegro III Piano Keys: passo 1, imagem 1 %32 How to Fix Stuck Williams Allegro III Piano Keys, How to Fix Stuck Williams Allegro III Piano Keys: passo 1, imagem 2 %32 How to Fix Stuck Williams Allegro III Piano Keys, How to Fix Stuck Williams Allegro III Piano Keys: passo 1, imagem 3 %32
    • Unplug the keyboard from the power source.
    • Flip the keyboard over so the bottom is facing up.
    • Make sure to unplug the keyboard as this is a necessary step to follow this guide safely.
    • Use a Phillips #0 screwdriver to remove eleven long screws from the back case.
    • Long screws are located on the outer edges of the back of the frame. A long-neck Phillips #0 screwdriver is recommended for these screws.
    • Use a Phillips #0 screwdriver to remove 27 short screws from the back of the keyboard.
    • There should be a total of 38 screws:11 long screws (indicated in red) and 27 short screws (indicated in orange).
  2. How to Fix Stuck Williams Allegro III Piano Keys: passo 2, imagem 1 %32 How to Fix Stuck Williams Allegro III Piano Keys: passo 2, imagem 2 %32
    • Flip your keyboard back over so the keys are showing.
    • Gently remove the top frame.
  3. How to Fix Stuck Williams Allegro III Piano Keys: passo 3, imagem 1 %32 How to Fix Stuck Williams Allegro III Piano Keys: passo 3, imagem 2 %32 How to Fix Stuck Williams Allegro III Piano Keys: passo 3, imagem 3 %32
    • Unclip each key that is stuck or needs repair and pull it off the board carefully.
    • You may need to use tweezers to push down the small blue clip on one end while you pry up the opposite end of the key.
  4. How to Fix Stuck Williams Allegro III Piano Keys: passo 4, imagem 1 %32
    • Check the underside of the key(s) for a build-up of dust, dirt, or crumbs, and brush it off using an anti-static brush.
  5. How to Fix Stuck Williams Allegro III Piano Keys: passo 5, imagem 1 %32 How to Fix Stuck Williams Allegro III Piano Keys: passo 5, imagem 2 %32 How to Fix Stuck Williams Allegro III Piano Keys: passo 5, imagem 3 %32
    • Check that the hammer (gray piece) and clip (blue piece) are in line with each other.
    • Every hammer should have a corresponding small, black rubber pad on top.
    • If the rubber pad is loose, misaligned, or falling off, it is important to superglue it back into place similar to how the other key pads look.
  6. How to Fix Stuck Williams Allegro III Piano Keys: passo 6, imagem 1 %32 How to Fix Stuck Williams Allegro III Piano Keys: passo 6, imagem 2 %32 How to Fix Stuck Williams Allegro III Piano Keys: passo 6, imagem 3 %32
    • Use your fingers to carefully bend the key alignments until they are parallel with each other.
  7. How to Fix Stuck Williams Allegro III Piano Keys: passo 7, imagem 1 %32 How to Fix Stuck Williams Allegro III Piano Keys: passo 7, imagem 2 %32 How to Fix Stuck Williams Allegro III Piano Keys: passo 7, imagem 3 %32
    • Clip the key back onto the keyboard by pressing down on each end, one at a time.
    • This method will ensure that you can hear and feel each key end clip into place correctly.
  8. How to Fix Stuck Williams Allegro III Piano Keys: passo 8, imagem 1 %32
    • Plug the keyboard back into the electrical source and test the sound of the key you are fixing.
    • If sound has not improved or the key remains stuck, then repeat steps 3-7 to ensure the key is properly cleaned and correctly attached.
Conclusão
To reassemble your device, follow steps 7 and 9. This guide can be used for multiple key repairs as long as you repeat the necessary steps for each stuck key.
Uma outra pessoa concluiu este guia.
Jaydon S
Membro desde: 03/05/24
172 Reputação
Autoria de 1 guia
Equipe
Um comentário
@jaydons82612 I've noticed your phone number on your about page. Sharing is cool but oversharing can lead to a lot of unwanted Spam and phone calls. You do want to do yourself a favor and remove the phone number. BTW, cool guide
oldturkey03 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 24
Duração total: 90
