Ir para o conteúdo principal
How to Fix Sticky Surfaces on a Cast Iron Skillet
O que você precisa
  1. How to Fix Sticky Surfaces on a Cast Iron Skillet, How to Fix Sticky Surfaces on a Cast Iron Skillet: passo 1, imagem 1 %32
    • Clean the skillet thoroughly with soap and water.
  2. How to Fix Sticky Surfaces on a Cast Iron Skillet: passo 2, imagem 1 %32 How to Fix Sticky Surfaces on a Cast Iron Skillet: passo 2, imagem 2 %32
    • Scrub the entire pan with steel wool.
    • After scrubbing the skillet, dry it off using a towel or paper towels. You can also place the skillet on a stove top for 30-45 seconds to dry it.
    • The layer of seasoning has now been completely removed, and will be restored in the following steps.
  3. How to Fix Sticky Surfaces on a Cast Iron Skillet: passo 3, imagem 1 %32
    • Pre-heat the oven to 500°F. (If your oven does not go this high, use the highest temperature.)
  4. How to Fix Sticky Surfaces on a Cast Iron Skillet: passo 4, imagem 1 %32 How to Fix Sticky Surfaces on a Cast Iron Skillet: passo 4, imagem 2 %32 How to Fix Sticky Surfaces on a Cast Iron Skillet: passo 4, imagem 3 %32
    • Lightly coat the skillet in a thin layer of vegetable oil.
    • Use a paper towel to evenly spread the oil over the entire pan, including the handle bar. The skillet should look somewhat shiny after this.
    • Grab a dry paper towel and go over the surfaces one more time to remove excess oil.
  5. How to Fix Sticky Surfaces on a Cast Iron Skillet: passo 5, imagem 1 %32
    • Place skillet in the oven upside down for 1 hour.
    • Place a piece of aluminum foil under the pan in case any oil drips.
  6. How to Fix Sticky Surfaces on a Cast Iron Skillet: passo 6, imagem 1 %32
    • After one hour, remove the skillet from the oven using an oven mitt.
Conclusão
The skillet should no longer have any sticky surfaces, and should cook as if it were new. To prevent damage to the seasoned layer, be careful with metal spatulas and make sure to only wash the skillet with soap and steel wool if you are removing a damaged layer to apply a new one.
Liam McKenzie
Membro desde: 03/22/21
133 Reputação
Autoria de 1 guia
Equipe
2 comentários
Step number 6 kinda leaves me hanging. Is there anything else to do, or a Step 7?
David Rhodes - Responder
That’s it. The only thing left to do now is cook an awesome dish in your cast iron.
Stacy White -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 15
Últimos 7 dias: 72
Últimos 30 dias: 306
Duração total: 3,551
