Ir para o conteúdo principal
How to Fix Scratches on a Steel Watch
O que você precisa
  1. How to Fix Scratches on a Steel Watch, How to Fix Scratches on a Steel Watch: passo 1, imagem 1 %32
    • Fill any container up with water.
  2. How to Fix Scratches on a Steel Watch: passo 2, imagem 1 %32
    • Grab any soft-bristled brush around for your convenience.
  3. How to Fix Scratches on a Steel Watch: passo 3, imagem 1 %32 How to Fix Scratches on a Steel Watch: passo 3, imagem 2 %32 How to Fix Scratches on a Steel Watch: passo 3, imagem 3 %32
    • Dip the toothbrush in the water.
    • Brush along the crystal, bezel, and case in a circular motion.
    • Brush the bracelet in a linear motion back-and-forth.
    • Make sure to brush over the crevices of the bracelet for an optimal clean.
  4. How to Fix Scratches on a Steel Watch: passo 4, imagem 1 %32
    Ferramenta utilizada neste passo:
    Microfiber Cleaning Cloths
    $3.99
    • Dry the watch with a microfiber towel by pinching your fingers together in a back-and-forth motion.
  5. How to Fix Scratches on a Steel Watch: passo 5, imagem 1 %32
    • Use the abrasive side of a sponge to brush the watch, following the same steps mentioned in Step 3.
    • Do not brush over the crystal with the sponge.
    • Apply minimal pressure to the sponge when brushing the watch.
  6. How to Fix Scratches on a Steel Watch: passo 6, imagem 1 %32
    • Fold the metal polishing cloth in half.
    • Hold the corner of the cloth along your index finger.
  7. How to Fix Scratches on a Steel Watch: passo 7, imagem 1 %32
    • Brush off all the scratches on the watch using a back-and-forth motion with great pressure to ensure effectiveness.
    • Perform the process as many times as needed.
    • Do not brush over the crystal.
Linha de Chegada
Uma outra pessoa concluiu este guia.
Youssefmo
Membro desde: 08/31/22
219 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 8
Últimos 30 dias: 38
Ao todo: 809
