Ir para o conteúdo principal
How to Fix Ray-Ban Clubmaster Eyeglasses
O que você precisa
  1. How to Fix Ray-Ban Clubmaster Eyeglasses, How to Fix Ray-Ban Clubmaster Eyeglasses: passo 1, imagem 1 %32
    • Using the toothpick, remove any manufacturing adhesive inside the top bar of the frame.
  2. How to Fix Ray-Ban Clubmaster Eyeglasses: passo 2, imagem 1 %32
    • Apply rubbing alcohol to a cotton ball and clean inside the top bar of the Clubmaster frame.
  3. How to Fix Ray-Ban Clubmaster Eyeglasses: passo 3, imagem 1 %32 How to Fix Ray-Ban Clubmaster Eyeglasses: passo 3, imagem 2 %32
    • Let the alcohol dry and apply a thin layer of super glue along the inside of the top bar of the frame, from edge to edge.
    • The glue should not be overflowing out of the top bar.
    • Wear disposable gloves to avoid contact with skin.
  4. How to Fix Ray-Ban Clubmaster Eyeglasses: passo 4, imagem 1 %32
    • Firmly press the glasses lens(es) inside the frame.
  5. How to Fix Ray-Ban Clubmaster Eyeglasses: passo 5, imagem 1 %32
    • Wipe away any excess glue on the lens(es) and frame with a piece of paper towel.
    • Avoid smudging the glue on the glasses.
  6. How to Fix Ray-Ban Clubmaster Eyeglasses: passo 6, imagem 1 %32 How to Fix Ray-Ban Clubmaster Eyeglasses: passo 6, imagem 2 %32
    • Place the glasses upside down on a piece of paper towel and set in a cool place to dry for 24 hours.
Conclusão
If the guide is followed properly your Clubmaster eyeglasses should hold up perfectly!
4 outras pessoas executaram este guia.
Amanuel Demeke
Membro desde: 01/21/21
214 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 9
Últimos 7 dias: 23
Últimos 30 dias: 102
Duração total: 3,264
