Ir para o conteúdo principal
How to Fix RV Toilet Water Pressure
O que você precisa
    1. How to Fix RV Toilet Water Pressure, How to Fix RV Toilet Water Pressure: passo 1, imagem 1 %32 How to Fix RV Toilet Water Pressure, How to Fix RV Toilet Water Pressure: passo 1, imagem 2 %32 How to Fix RV Toilet Water Pressure, How to Fix RV Toilet Water Pressure: passo 1, imagem 3 %32
      • Wrap the thread tape around the 1/2" nipple, 2-3 times in a counter-clockwise motion.
      • Make sure the nipple is fully covered, but the ends are open.
      Pergunte ao FixBot
      Comentar
    2. How to Fix RV Toilet Water Pressure: passo 2, imagem 1 %32 How to Fix RV Toilet Water Pressure: passo 2, imagem 2 %32
      • Screw the nipple onto the regulator, making sure the arrow (marked by the red circle) is pointing away from the nipple.
      • Be sure to screw the nipple in as tight as you can with just your fingers.
      Pergunte ao FixBot
      Comentar
    3. How to Fix RV Toilet Water Pressure: passo 3, imagem 1 %32 How to Fix RV Toilet Water Pressure: passo 3, imagem 2 %32 How to Fix RV Toilet Water Pressure: passo 3, imagem 3 %32
      • Wrap the thread tape around the pressure gauge 2-3 times, in a counter-clockwise motion.
      • Make sure the thread is fully covered, but the end is open.
      • Do not thread the gauge in yet. Instead, note the angled slot where it will be installed in step 10.
      Pergunte ao FixBot
      Comentar
    4. How to Fix RV Toilet Water Pressure: passo 4, imagem 1 %32 How to Fix RV Toilet Water Pressure: passo 4, imagem 2 %32 How to Fix RV Toilet Water Pressure: passo 4, imagem 3 %32
      • Turn the external water source (outside faucet) off.
      Pergunte ao FixBot
      Comentar
    5. How to Fix RV Toilet Water Pressure: passo 5, imagem 1 %32
      • Turn on the sink faucet and let it run until no more water comes out to drain the lines.
      • Flush the toilet to drain any remaining water in the lines.
      Pergunte ao FixBot
      Comentar
    6. How to Fix RV Toilet Water Pressure: passo 6, imagem 1 %32 How to Fix RV Toilet Water Pressure: passo 6, imagem 2 %32
      • Unscrew the water inlet line from the toilet.
      • Lay a towel down as some water may drip out.
      Pergunte ao FixBot
      Comentar
    7. How to Fix RV Toilet Water Pressure: passo 7, imagem 1 %32 How to Fix RV Toilet Water Pressure: passo 7, imagem 2 %32
      • Screw the regulator onto the back of the toilet where the water line was screwed in.
      • The arrow should point to the back of the toilet.
      Pergunte ao FixBot
      Comentar
    8. How to Fix RV Toilet Water Pressure: passo 8, imagem 1 %32 How to Fix RV Toilet Water Pressure: passo 8, imagem 2 %32 How to Fix RV Toilet Water Pressure: passo 8, imagem 3 %32
      • Screw the water inlet line onto the nipple attached to the regulator.
      • This may be difficult, but be sure NOT to cross-thread.
      • Make sure to screw it in tight (finger tight), but do not over tighten.
      Pergunte ao FixBot
      Comentar
    9. How to Fix RV Toilet Water Pressure: passo 9, imagem 1 %32 How to Fix RV Toilet Water Pressure: passo 9, imagem 2 %32
      • Screw the pressure gauge onto the regulator.
      • Tighten it all the way down as far as you can with finger strength.
      Pergunte ao FixBot
      Comentar
    10. How to Fix RV Toilet Water Pressure: passo 10, imagem 1 %32 How to Fix RV Toilet Water Pressure: passo 10, imagem 2 %32 How to Fix RV Toilet Water Pressure: passo 10, imagem 3 %32
      • Turn the water back on.
      Pergunte ao FixBot
      Comentar
    11. How to Fix RV Toilet Water Pressure: passo 11, imagem 1 %32
      • Check to make sure nothing is leaking.
      • If one of the fittings is leaking you may need to remove it and put more tape on the nipple.
      Pergunte ao FixBot
      Comentar
    12. How to Fix RV Toilet Water Pressure: passo 12, imagem 1 %32 How to Fix RV Toilet Water Pressure: passo 12, imagem 2 %32 How to Fix RV Toilet Water Pressure: passo 12, imagem 3 %32
      • Remove the cap from the top of the regulator.
      Pergunte ao FixBot
      Comentar
    13. How to Fix RV Toilet Water Pressure: passo 13, imagem 1 %32 How to Fix RV Toilet Water Pressure: passo 13, imagem 2 %32 How to Fix RV Toilet Water Pressure: passo 13, imagem 3 %32
      • Take the Allen Key and insert it in the top of the regulator.
      • Twist the Allen Key while running water into the toilet until the desired water pressure is achieved.
      Pergunte ao FixBot
      Comentar
    14. How to Fix RV Toilet Water Pressure: passo 14, imagem 1 %32 How to Fix RV Toilet Water Pressure: passo 14, imagem 2 %32 How to Fix RV Toilet Water Pressure: passo 14, imagem 3 %32
      • Screw the cap back on to the regulator.
      • Enjoy the new water pressure.
      Pergunte ao FixBot
      Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 76
Ao todo: 733
