Introdução
This guide will show you how to repair a crack in a generic plastic chair. The cracks this guide specifically addresses include partial cracks on the chair body/legs and full cracks on the chair spindle.
This guide focuses on how to repair a crack on the chair spindle. It involves making a new seal for the crack using super glue and baking soda and sanding it down to bring the broken area back to its original look.
Warning: Work in an area with good ventilation. Isopropyl alcohol is flammable. Additionally, wear protective clothing to avoid getting super glue on your clothes or skin.
O que você precisa
Lay the broken chair such that the crack is parallel to the floor.
After ten minutes, brush away some of the un-glued baking soda to check if the glue is solid.
Y para una pata de silla Rota que hacer ?
Existe remedio para la pata de una silla de plástico rota .?
The crack has been repaired!
13 outras pessoas executaram este guia.
3 comentários
Do you push the baking soda down into the glue (or into the crack), or just spread evenly on the surface?
What glue did you use?
