Ir para o conteúdo principal
How to Fix PS4 Controller Joystick Drift Without Disassembling
O que você precisa
  1. How to Fix PS4 Controller Joystick Drift Without Disassembling, How to Fix PS4 Controller Joystick Drift Without Disassembling: passo 1, imagem 1 %32
    • Before you begin, make sure your PlayStation 4 controller is not connected to the console or any cables.
  2. How to Fix PS4 Controller Joystick Drift Without Disassembling: passo 2, imagem 1 %32
    • Dip a cotton swab in rubbing alcohol.
  3. How to Fix PS4 Controller Joystick Drift Without Disassembling: passo 3, imagem 1 %32
    • Use the cotton swab with rubbing alcohol to clean the joystick and its base of any debris or dust.
  4. How to Fix PS4 Controller Joystick Drift Without Disassembling: passo 4, imagem 1 %32
    • Let the controller dry for about 10 to 15 minutes.
  5. How to Fix PS4 Controller Joystick Drift Without Disassembling: passo 5, imagem 1 %32
    • Spray compressed air around the base of the joystick to further remove any dust or debris.
    • Make sure the can of compressed air is level to avoid adding moisture to the joystick.
  6. How to Fix PS4 Controller Joystick Drift Without Disassembling: passo 6, imagem 1 %32
    • Press forward on the thumbsticks for 30 seconds.
  7. How to Fix PS4 Controller Joystick Drift Without Disassembling: passo 7, imagem 1 %32
    • Press down on the joystick and move it 360 degrees clockwise and counter-clockwise for 30 seconds.
  8. How to Fix PS4 Controller Joystick Drift Without Disassembling: passo 8, imagem 1 %32
    • Turn on the console to begin rebooting your controller.
  9. How to Fix PS4 Controller Joystick Drift Without Disassembling: passo 9, imagem 1 %32
    • Disconnect your controller once more from the console.
  10. How to Fix PS4 Controller Joystick Drift Without Disassembling: passo 10, imagem 1 %32
    • Press the tip of a small paper clip into the reset button on the back of the controller and hold for ten seconds.
    • After ten seconds, your controller will reboot.
Linha de Chegada
5 outras pessoas executaram este guia.
Murtaza Lutfi
Membro desde: 01/15/22
309 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 104
Últimos 7 dias: 643
Últimos 30 dias: 2,972
Duração total: 20,211
