Ir para o conteúdo principal
How to Fix Faulty Logitech G29 Pedals
O que você precisa
  1. How to Fix Faulty Logitech G29 Pedals, How to Fix Faulty Logitech G29 Pedals: passo 1, imagem 1 %32 How to Fix Faulty Logitech G29 Pedals, How to Fix Faulty Logitech G29 Pedals: passo 1, imagem 2 %32 How to Fix Faulty Logitech G29 Pedals, How to Fix Faulty Logitech G29 Pedals: passo 1, imagem 3 %32
    • Remove the four 30 mm screws from the left and middle pedals using a 1/8 hex key.
    • Remove the two 16.3 mm screws from the right pedal using a 1/8 hex key.
    • Pull the silver pedal plates off of each pedal.
  2. How to Fix Faulty Logitech G29 Pedals: passo 2, imagem 1 %32 How to Fix Faulty Logitech G29 Pedals: passo 2, imagem 2 %32
    • Flip the pedal set over so it is facing down.
    • Remove twelve 15.8 mm screws from the bottom using a Phillips #1 screwdriver,
    • Remove two 15.8 mm screws hidden behind the rug grip using a Phillips #1 screwdriver.
    • These metal screws are screwed into plastic, so do not overtighten them when reassembling, or you might strip the anchor points.
  3. How to Fix Faulty Logitech G29 Pedals: passo 3, imagem 1 %32 How to Fix Faulty Logitech G29 Pedals: passo 3, imagem 2 %32 How to Fix Faulty Logitech G29 Pedals: passo 3, imagem 3 %32
    • Slowly and carefully lift the top housing up from the set.
    • Do not pull the top housing too far, as a cable is anchored to the top housing, which needs to be unscrewed in the next step.
  4. How to Fix Faulty Logitech G29 Pedals: passo 4, imagem 1 %32 How to Fix Faulty Logitech G29 Pedals: passo 4, imagem 2 %32
    • Using a Phillips #1 screwdriver, remove two 7.4 mm screws that hold the cable to the top housing.
  5. How to Fix Faulty Logitech G29 Pedals: passo 5, imagem 1 %32
    • Flip the pedal set onto its side.
    • Each pedal is held in place with four screws.
    • Using a Phillips #1 screwdriver, remove the four 15.8 mm screws corresponding to the pedal you want to fix.
    • In this guide, I will be working on the gas pedal only. The process is the same for each pedal.
    • Once the four screws are removed, you can remove the pedal from the base to get a clearer view and access to the potentiometer and its connections.
  6. How to Fix Faulty Logitech G29 Pedals: passo 6, imagem 1 %32 How to Fix Faulty Logitech G29 Pedals: passo 6, imagem 2 %32 How to Fix Faulty Logitech G29 Pedals: passo 6, imagem 3 %32
    • The color of the wires are different for each pedal. Keep note of the color of the wires, and which goes where.
    • Using a Phillips #1 screwdriver, remove the single 6.2 mm screw holding the ground ring in place.
    • Using a pair of pliers, remove the three connections carefully.
    • When pulling on the three connection points, there may be some resistance. Do not pull too hard; if you yank on the cable too hard while it's out, it might damage the cable itself.
  7. How to Fix Faulty Logitech G29 Pedals: passo 7, imagem 1 %32 How to Fix Faulty Logitech G29 Pedals: passo 7, imagem 2 %32
    • Check the terminals for any debris or particles that might be in the way. Ensure the terminals are clean so that the connection is not interrupted.
    • Check the ground ring and where it connects to make sure no debris or particles are in the way. The ground ring needs to be directly touching the metal on the pedal for it to work properly.
    • If the connections are dirty, wipe them using isopropyl alcohol.
  8. How to Fix Faulty Logitech G29 Pedals: passo 8, imagem 1 %32 How to Fix Faulty Logitech G29 Pedals: passo 8, imagem 2 %32 How to Fix Faulty Logitech G29 Pedals: passo 8, imagem 3 %32
    • Reinsert the wires into the terminals.
    • Make sure the wire fits all the way in, as shown in the second picture.
    • If the connection still feels somewhat loose or shaky, squeeze the connection a little bit to make it more tight, ensuring it wont undo itself over time.
  9. How to Fix Faulty Logitech G29 Pedals: passo 9, imagem 1 %32
    • Reinsert the ground pin and screw it in.
  10. How to Fix Faulty Logitech G29 Pedals: passo 10, imagem 1 %32
    • Spray compressed air into the potentiometer to remove any dust/debris/hair/fur that may be inside the potentiometer.
Conclusão
To reassemble your device, follow steps 1-5 in reverse order.
9 outras pessoas executaram este guia.
Jeremy Sukhai
Membro desde: 01/17/22
381 Reputação
Autoria de 1 guia
Equipe
15 comentários
Jeremy thank you so much for the information very helpful. I have a question what if I was wanting to have my throttle to run wide open when I get off the throttle and decelerate when I push down on the throttle kinda like a dozer there for not wanting to have to push on the throttle all the time
Bill Davis - Responder
This could be achieved through software rather then altering the pedals itself. Most games or software will provide you with options to customize the functionality of pedals, that way you can invert the input so 0input=full throttle and 100input=no throttle. If you cant do this through software, you could swap the 5v and ground connections which are the connections not in the middle. This will reverse the voltage reading for the potentiometer, then the throttle will be wide open by default, and decelerate when you press the pedal.
Jeremy Sukhai -
Thank you Jeremy so much I will try to do this.
Im having a problem where the throttle accelerates wide open when i let off the pedal but when i push on the pedal it decelerates, how can i fix this?
Octavio Reyes - Responder
Im having a problem where my brake doesn't work and when I accelerate it also activates the brake. How can I fix this
James Stanford - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 62
Últimos 7 dias: 480
Últimos 30 dias: 2,161
Duração total: 52,914
