Ir para o conteúdo principal
Introdução
A cracked door frame can often deteriorate in time but can be salvaged when fixed with a repair kit. This guide will help homeowners repair cracks in the door frame on their own and at a very low cost, without having to replace the entire door frame.
  1. How to Fix Cracked Door Jamb, How to Fix Cracked Door Jamb: passo 1, imagem 1 %32
    • Cracked door jamb/frame caused by excessive force on door.
  2. How to Fix Cracked Door Jamb: passo 2, imagem 1 %32
    • Apply wood filler into the cracks of the door frame.
  3. How to Fix Cracked Door Jamb: passo 3, imagem 1 %32 How to Fix Cracked Door Jamb: passo 3, imagem 2 %32
    • Attach the clamp onto the cracked door frame.
    • Use a clamp with rubber edges for a sturdier grip and also to prevent damaging the door frame.
  4. How to Fix Cracked Door Jamb: passo 4, imagem 1 %32 How to Fix Cracked Door Jamb: passo 4, imagem 2 %32
    • Drill a pilot hole into the door frame.
    • Screw a 4-inch screw into the frame through the pilot hole.
  5. How to Fix Cracked Door Jamb: passo 5, imagem 1 %32
    • Wait for the wood filler to dry.
    • Once dried, scrape off the excess filler with a scraper.
  6. How to Fix Cracked Door Jamb: passo 6, imagem 1 %32
    • Sand the filled up cracks to get a smooth surface.
  7. How to Fix Cracked Door Jamb: passo 7, imagem 1 %32
    • Paint and do not touch until dry.
  8. How to Fix Cracked Door Jamb: passo 8, imagem 1 %32 How to Fix Cracked Door Jamb: passo 8, imagem 2 %32
    • Repaired door frame/ door jamb.
Linha de Chegada
4 outras pessoas concluíram este guia.
Anisha Karaumbiah
Membro desde: 17/02/2018
256 Reputação
Autoria de 1 guia
UC Davis, Team S1-G1, Andersen Winter 2018 Membro de UC Davis, Team S1-G1, Andersen Winter 2018
UCD-ANDERSEN-W18S1G1
1 Membro
1 Guia de autoria
0 Comments
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 27
Últimos 7 dias: 161
Últimos 30 dias: 749
Duração total: 31,165
