Ir para o conteúdo principal
How to Fix Broken Porch Entry Stairs
O que você precisa
  1. How to Fix Broken Porch Entry Stairs, Stair treads and risers: passo 1, imagem 1 %32 How to Fix Broken Porch Entry Stairs, Stair treads and risers: passo 1, imagem 2 %32 How to Fix Broken Porch Entry Stairs, Stair treads and risers: passo 1, imagem 3 %32
    • Use a pry bar to remove the pre-existing damaged wood pieces.
    • Start with the riser first.
    • Be mindful of possible rusted screws/nails.
  2. How to Fix Broken Porch Entry Stairs: passo 2, imagem 1 %32 How to Fix Broken Porch Entry Stairs: passo 2, imagem 2 %32 How to Fix Broken Porch Entry Stairs: passo 2, imagem 3 %32
    • Remove the treads on the stairs.
  3. How to Fix Broken Porch Entry Stairs: passo 3, imagem 1 %32 How to Fix Broken Porch Entry Stairs: passo 3, imagem 2 %32
    • Use a measuring tape to measure the foundation where the new steps will be placed.
    • To ensure accurate measurements, make sure to repeat this step twice.
  4. How to Fix Broken Porch Entry Stairs: passo 4, imagem 1 %32 How to Fix Broken Porch Entry Stairs: passo 4, imagem 2 %32 How to Fix Broken Porch Entry Stairs: passo 4, imagem 3 %32
    • Mark your measurements on both ends of your new weather treated wood using a measuring tape and a pencil.
    • For the best results, use a ruler to connect your marks into a straight line.
  5. How to Fix Broken Porch Entry Stairs: passo 5, imagem 1 %32
    • Place the new piece of wood onto the end of a sturdy table.
    • Make sure the marked end is hanging off the edge by at least a foot.
  6. How to Fix Broken Porch Entry Stairs: passo 6, imagem 1 %32
    • Use a circular saw to cut across the straight line marked on the new piece of wood.
    • Make sure the wood is secure by holding the end resting on the table the entire time.
    • Safety glasses should be worn during this step.
  7. How to Fix Broken Porch Entry Stairs: passo 7, imagem 1 %32 How to Fix Broken Porch Entry Stairs: passo 7, imagem 2 %32
    • Place the new piece of wood (riser) on the steps to ensure that it fits.
    • Use a leveler to make sure that it is level.
  8. How to Fix Broken Porch Entry Stairs: passo 8, imagem 1 %32 How to Fix Broken Porch Entry Stairs: passo 8, imagem 2 %32 How to Fix Broken Porch Entry Stairs: passo 8, imagem 3 %32
    • Secure your wood piece (riser) into place using a drill and galvanized screws.
    • Create two pilot holes with the correct drill bit.
    • Secure the wood (riser) into place by drilling 2" galvanized Phillips head screws into the pilot holes.
  9. How to Fix Broken Porch Entry Stairs: passo 9, imagem 1 %32
    • Make sure your wood piece (tread) fits into place and is level.
    • For the most accurate results, it is important to use a large level.
  10. How to Fix Broken Porch Entry Stairs: passo 10, imagem 1 %32 How to Fix Broken Porch Entry Stairs: passo 10, imagem 2 %32 How to Fix Broken Porch Entry Stairs: passo 10, imagem 3 %32
    • Secure your wood piece (tread) into place using a drill and galvanized screws.
    • Create three pilot holes with the correct drill bit.
    • Secure the wood (tread) into place by drilling 2" galvanized Phillips head screws into the pilot holes.
  11. How to Fix Broken Porch Entry Stairs: passo 11, imagem 1 %32
    • Repeat steps 8-10 for the remaining stairs.
    • For the best results, follow this guide thoroughly for each stair.
Conclusão
To reassemble your old stairs, follow these instructions in reverse order.
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 11
Últimos 7 dias: 100
Últimos 30 dias: 462
Duração total: 6,016
