Ir para o conteúdo principal
How to Fix Bent Silverware
O que você precisa
  1. How to Fix Bent Silverware, How to Fix Bent Silverware: passo 1, imagem 1 %32 How to Fix Bent Silverware, How to Fix Bent Silverware: passo 1, imagem 2 %32
    • First, clean with soap and water all of the bent silverware.
  2. How to Fix Bent Silverware: passo 2, imagem 1 %32
    • Take the pot and fill it halfway with water.
    • Put the pot on the stove and heat the water till it's boiling.
  3. How to Fix Bent Silverware: passo 3, imagem 1 %32
    • Place the bent silverware in the water for at least one minute.
  4. How to Fix Bent Silverware: passo 4, imagem 1 %32
    • After the minute is over, carefully pull out all of the silverware using pliers.
  5. How to Fix Bent Silverware: passo 5, imagem 1 %32
    • Dry off the silverware with either paper or cloth towels. Be careful not to burn yourself.
  6. How to Fix Bent Silverware: passo 6, imagem 1 %32 How to Fix Bent Silverware: passo 6, imagem 2 %32
    • Use tools such as pliers, a hard surface, rulers, and/or hammers to reshape silverware as desired.
  7. How to Fix Bent Silverware: passo 7, imagem 1 %32
    • When your done bending the silverware to its desired shape, let the silverware cool down to stay in that shape.
Linha de Chegada
4 outras pessoas executaram este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 8
Últimos 30 dias: 46
Ao todo: 3,800
