Ir para o conteúdo principal
How to Fix Anything
    1. How to Fix Anything, Define the Problem: passo 1, imagem 1 %32
      • Try to describe what your device is doing and what instead you expect it to do.
      Pergunte ao FixBot
      Comentar
      • If it is not obvious, check if the behaviour is actually a problem or not.
      • Pro tip: even if this is the intended behaviour, you are entitled to modify it, if you like. Just it's not "fixing" anymore: that's hacking!
      Pergunte ao FixBot
      Comentar
      • Did you forget to put the plug in the socket? Did you check the battery? Is the light bulb burn out?
      Pergunte ao FixBot
      Comentar
      • In Europe, everything has two years of warranty by law. Do not give up your rights!
      Pergunte ao FixBot
      Comentar
      • There is a very good chance that you will find something useful with a little search online.
      Pergunte ao FixBot
      Comentar
    2. How to Fix Anything, Talk to your Community: passo 6, imagem 1 %32
      • Speak with friends, family or colleagues. Even if they don't know anything, speaking helps a lot the reasoning.
      • Speak to a rubber duck
      Pergunte ao FixBot
      Comentar
    3. How to Fix Anything, Mind the safety.: passo 7, imagem 1 %32
      • Take a minute to think if there is anything that could be a safety hazard.
      • Check the user manual and the package, if available, and the device itself for any danger label.
      Pergunte ao FixBot
      Comentar
Conclusão
You are now ready to repair your stuff!
31 outras pessoas executaram este guia.
Davide
Membro desde: 07/15/16
1.108 Reputação
Autoria de 1 guia
6Comentários do guia
How to fix a 1998 fisher seph snow plow
Joseph427!@#$ - Responder Compartilhar
Estaría bien que pusieran un traductor para poder leer los comentarios de la gente
Gracias
Ruiz Marga - Responder Compartilhar
How to fix the spring in a Skoda Enyaq key fob.
Yvonne Pearson - Responder Compartilhar
@yvonnepearson This video shows you how to do it.
VauWeh - Responder Compartilhar
waxa aan ahay
Cabdi Cabdullahi - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 57
Últimos 7 dias: 446
Últimos 30 dias: 1,281
Ao todo: 14,568
