Ir para o conteúdo principal
How to Fix Analog Drift for the SCUF IMPACT
O que você precisa
  1. How to Fix Analog Drift for the SCUF IMPACT, How to Fix Analog Drift for the SCUF IMPACT: passo 1, imagem 1 %32 How to Fix Analog Drift for the SCUF IMPACT, How to Fix Analog Drift for the SCUF IMPACT: passo 1, imagem 2 %32 How to Fix Analog Drift for the SCUF IMPACT, How to Fix Analog Drift for the SCUF IMPACT: passo 1, imagem 3 %32
    • Unlock the L3 or R3 ring by turning it counter clockwise.
    • Remove the L3 or R3 ring.
  2. How to Fix Analog Drift for the SCUF IMPACT: passo 2, imagem 1 %32 How to Fix Analog Drift for the SCUF IMPACT: passo 2, imagem 2 %32 How to Fix Analog Drift for the SCUF IMPACT: passo 2, imagem 3 %32
    • Pull the analog gently in order to get it out.
  3. How to Fix Analog Drift for the SCUF IMPACT: passo 3, imagem 1 %32 How to Fix Analog Drift for the SCUF IMPACT: passo 3, imagem 2 %32 How to Fix Analog Drift for the SCUF IMPACT: passo 3, imagem 3 %32
    • Use a tweezer tip to gently open the green box.
  4. How to Fix Analog Drift for the SCUF IMPACT: passo 4, imagem 1 %32 How to Fix Analog Drift for the SCUF IMPACT: passo 4, imagem 2 %32 How to Fix Analog Drift for the SCUF IMPACT: passo 4, imagem 3 %32
    • Locate the sensor in the green box and take it out slowly.
  5. How to Fix Analog Drift for the SCUF IMPACT: passo 5, imagem 1 %32 How to Fix Analog Drift for the SCUF IMPACT: passo 5, imagem 2 %32 How to Fix Analog Drift for the SCUF IMPACT: passo 5, imagem 3 %32
    • Dip the q-tip in rubbing alcohol to clean the sensor and inside the green box for any dust or dirt.
  6. How to Fix Analog Drift for the SCUF IMPACT: passo 6, imagem 1 %32 How to Fix Analog Drift for the SCUF IMPACT: passo 6, imagem 2 %32 How to Fix Analog Drift for the SCUF IMPACT: passo 6, imagem 3 %32
    • Place the sensor back in the box. To reassemble your controller, follow the instructions 1-4 in reverse order.
Conclusão
Uma outra pessoa concluiu este guia.
Amirparsa Monshi
Membro desde: 09/27/21
157 Reputação
Autoria de 1 guia
Equipe
3 comentários
HIGHLY RECOMMENDED! You saved my life. I have a lot of stick drift in my left analog that ruined my gaming experience through running movement in most of my games (Warzone, Apex, Fortnite) and this tutorial fix it ! I had some black crap on the sensor when I take them off and rubbing it with alcohol and a fine needle solve it. Thanks so much!!!
Alexandre Beauregard - Responder
My green caps will not pop back on!!!
luke-froeba - Responder
Did this and got the boxes back on but now my stick is broke. Just get stuck whenever moving it up or down and cannot be pressed down any more..
Treyben Funderburg - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 14
Últimos 7 dias: 41
Últimos 30 dias: 129
Duração total: 24,439
