Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
For frisbee owners, a warped disc is a common problem due to prolonged sun exposure or moderate wear over time. For most discs, this warping can often be undone with some gentle manipulation. This fix involves a simple set up, and then letting the frisbee sit for approximately 1 hour.
O que você precisa
Place the frisbee disc on a flat surface with the concave side facing up. Lay a towel down flat over the frisbee.
The time taken to fix the warping on your frisbee may vary based on how thick the plastic is.
