Ir para o conteúdo principal
How to Fix A Stripped Screw Hole
O que você precisa
  1. How to Fix A Stripped Screw Hole, How to Fix A Stripped Screw Hole: passo 1, imagem 1 %32
    • Using the toothpick as a reference, measure the depth of the screw-hole and the number of toothpicks needed to fill the screw hole.
  2. How to Fix A Stripped Screw Hole: passo 2, imagem 1 %32 How to Fix A Stripped Screw Hole: passo 2, imagem 2 %32
    • Next, using the wood glue, cover the area of the toothpick(s) that will fill in the screw hole.
  3. How to Fix A Stripped Screw Hole: passo 3, imagem 1 %32 How to Fix A Stripped Screw Hole: passo 3, imagem 2 %32
    • Place the toothpicks into the screw hole.
  4. How to Fix A Stripped Screw Hole: passo 4, imagem 1 %32
    • Now, break off the exposed segment of the toothpick(s).
  5. How to Fix A Stripped Screw Hole: passo 5, imagem 1 %32
    • Clean off the excess and let the wood glue dry for up to 30 minutes.
    • Recommended wood glue drying time may vary by product.
  6. How to Fix A Stripped Screw Hole: passo 6, imagem 1 %32 How to Fix A Stripped Screw Hole: passo 6, imagem 2 %32
    • Finally, using the screwdriver, screw the screw into the repaired screw hole.
Conclusão
Your screw should now hold secure.
Isaiah Valdez Mireles
Membro desde: 08/22/22
133 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 13
Ao todo: 1,995
