Ir para o conteúdo principal
How to Fix A Rusted Hitch
O que você precisa
    1. How to Fix A Rusted Hitch, How to Fix A Rusted Hitch: passo 1, imagem 1 %32
      • This is the before picture of the rusted hitch.
      Pergunte ao FixBot
      Comentar
    2. How to Fix A Rusted Hitch: passo 2, imagem 1 %32
      • Apply the wire brush on any part of the hitch in order to brush off any excess rust or rust flakes.
      Pergunte ao FixBot
      Comentar
    3. How to Fix A Rusted Hitch: passo 3, imagem 1 %32 How to Fix A Rusted Hitch: passo 3, imagem 2 %32
      • Use the small paint brush to apply a coat of naval jelly over the rusted area.
      • Allow to sit for approximately ten minutes.
      • Remember to use caution/gloves when handling the naval jelly.
      Pergunte ao FixBot
      Comentar
    4. How to Fix A Rusted Hitch: passo 4, imagem 1 %32
      • Dip the paper towel in a bowl of lukewarm water to get the paper towel damp.
      Pergunte ao FixBot
      Comentar
    5. How to Fix A Rusted Hitch: passo 5, imagem 1 %32
      • Take the wet paper towel and wipe off the naval jelly on the hitch.
      Pergunte ao FixBot
      Comentar
    6. How to Fix A Rusted Hitch: passo 6, imagem 1 %32
      • Apply a protective layer of fluid film to the treated area.
      • Spray approximately 4-6 inches away from the hitch.
      Pergunte ao FixBot
      Comentar
    7. How to Fix A Rusted Hitch: passo 7, imagem 1 %32
      • Allow the fluid film to sit for about 5 minutes.
      • You should start to see bubbling in this process.
      Pergunte ao FixBot
      Comentar
    8. How to Fix A Rusted Hitch: passo 8, imagem 1 %32
      • This is the finished, rust-free, product.
      Pergunte ao FixBot
      Comentar
Conclusão
This procedure cannot be performed again immediately after the rust is taken off. Repeat these steps when rust develops over time.
Uma outra pessoa concluiu este guia.
Kiley Strickland
Membro desde: 01/20/19
184 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 20
Últimos 30 dias: 113
Ao todo: 2,883
