Ir para o conteúdo principal
How to Fix A Loose RCA RT3205 TV Stand
O que você precisa
  1. How to Fix A Loose RCA RT3205 TV Stand, How to Fix A Loose RCA RT3205 TV Stand: passo 1, imagem 1 %32
    • Place a soft cushioned material on top of a flat surface, like a table.
    • This is to prevent damaging the TV screen panel.
    • Make sure your path towards the TV is clear of any obstructions. If not, remove all obstacles.
  2. How to Fix A Loose RCA RT3205 TV Stand: passo 2, imagem 1 %32 How to Fix A Loose RCA RT3205 TV Stand: passo 2, imagem 2 %32 How to Fix A Loose RCA RT3205 TV Stand: passo 2, imagem 3 %32
    • Unplug the TV set from the power supply.
    • Keep TV set unplugged until repair is completed.
    • Failure to unplug the TV can result in a hazardous situation which, if not avoided, could result in death or serious injury.
  3. How to Fix A Loose RCA RT3205 TV Stand: passo 3, imagem 1 %32
    • Place the TV monitor flat on top, with the screen side facing down.
  4. How to Fix A Loose RCA RT3205 TV Stand: passo 4, imagem 1 %32
    • Align the stand(s) onto the bottom of the TV.
    • If the stands have been installed already, remove them and realign.
  5. How to Fix A Loose RCA RT3205 TV Stand: passo 5, imagem 1 %32 How to Fix A Loose RCA RT3205 TV Stand: passo 5, imagem 2 %32
    • Align the screw holes on the stand and to the bottom of the TV.
  6. How to Fix A Loose RCA RT3205 TV Stand: passo 6, imagem 1 %32
    • Gently tighten the screws with a screwdriver to fasten the stand to the panel.
    • A table knife can be used in place of a screwdriver.
Conclusão
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 18
Ao todo: 728
