Ir para o conteúdo principal
How to Fix A Crooked Cabinet Door
O que você precisa
  1. How to Fix A Crooked Cabinet Door, How to Fix A Crooked Cabinet Door: passo 1, imagem 1 %32
    • Open the cabinet door, and determine where it is misaligned.
  2. How to Fix A Crooked Cabinet Door: passo 2, imagem 1 %32
    • Re-attach the hinge into place.
    • Soft-closing multi-adjustable hinges can snap back into their thickness plates which is the part attached to the inside of the cabinet.
    • Avoid placing your fingers near the thickness plate as its force can cause a painful pinch.
  3. How to Fix A Crooked Cabinet Door: passo 3, imagem 1 %32
    • Hold the hinge firmly against the thickness plate and tighten the screw until the hinge is no longer loose.
    • There are different methods for aligning your cabinet door depending on the screw you tighten and the direction:
    • Side-to-Side Adjustment: To move the door away from the cabinet, screw clockwise. To move the door closer to the cabinet, screw in a counterclockwise motion.
    • Up-Down Adjustment: Screw in a clockwise motion to move the door up. A counterclockwise motion will move the door down.
  4. How to Fix A Crooked Cabinet Door: passo 4, imagem 1 %32
    • The result of the tightened hinge will look as pictured.
  5. How to Fix A Crooked Cabinet Door: passo 5, imagem 1 %32
    • Measure along the top and sides of the cabinet with a balance ruler or standard ruler.
    • The result should look as pictured.
Linha de Chegada
Uma outra pessoa concluiu este guia.
Camrynne Paul
Membro desde: 03/19/22
121 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 17
Últimos 7 dias: 119
Últimos 30 dias: 485
Duração total: 3,866
