Ir para o conteúdo principal
How to Fix A Broken Makeup Compact Without Alcohol
O que você precisa
  1. How to Fix A Broken Makeup Compact Without Alcohol, How to Fix A Broken Makeup Compact Without Alcohol: passo 1, imagem 1 %32
    • Plug In the iron and turn the heat to the highest setting.
    • Caution: Be sure to place the iron on a flat, solid surface, away from plastic and other flammable objects.
  2. How to Fix A Broken Makeup Compact Without Alcohol: passo 2, imagem 1 %32
    • Pour the broken powder into a plastic sandwich bag.
  3. How to Fix A Broken Makeup Compact Without Alcohol: passo 3, imagem 1 %32
    • Use a spoon to break the powder down into a fine dust.
  4. How to Fix A Broken Makeup Compact Without Alcohol: passo 4, imagem 1 %32 How to Fix A Broken Makeup Compact Without Alcohol: passo 4, imagem 2 %32
    • Take a knife and carefully remove the metal pan from the compact.
  5. How to Fix A Broken Makeup Compact Without Alcohol: passo 5, imagem 1 %32 How to Fix A Broken Makeup Compact Without Alcohol: passo 5, imagem 2 %32 How to Fix A Broken Makeup Compact Without Alcohol: passo 5, imagem 3 %32
    • Pour the powder into the metal pan and begin to press the powder down with the spoon.
  6. How to Fix A Broken Makeup Compact Without Alcohol: passo 6, imagem 1 %32 How to Fix A Broken Makeup Compact Without Alcohol: passo 6, imagem 2 %32 How to Fix A Broken Makeup Compact Without Alcohol: passo 6, imagem 3 %32
    • Turn the heat off on the iron.
    • Caution: Be sure to unplug the iron.
    • Use the heat from the iron to secure the powder in the pan.
    • Press down for 15 seconds at a time.
    • Repeat as needed.
  7. How to Fix A Broken Makeup Compact Without Alcohol: passo 7, imagem 1 %32 How to Fix A Broken Makeup Compact Without Alcohol: passo 7, imagem 2 %32 How to Fix A Broken Makeup Compact Without Alcohol: passo 7, imagem 3 %32
    • Let cool completely.
    • Place metal pan back into the compact.
    • Now the compact is ready for use.
Linha de Chegada
Cura Mclemore
Membro desde: 03/21/23
145 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 14
Ao todo: 413
