Ir para o conteúdo principal
How to Factory / Hard Reset Nokia Lumia 520
Vídeo de Apresentação
  1. How to Factory / Hard Reset Nokia Lumia 520, How to Factory / Hard Reset Nokia Lumia 520: passo 1, imagem 1 %32 How to Factory / Hard Reset Nokia Lumia 520, How to Factory / Hard Reset Nokia Lumia 520: passo 1, imagem 2 %32 How to Factory / Hard Reset Nokia Lumia 520, How to Factory / Hard Reset Nokia Lumia 520: passo 1, imagem 3 %32
    • 1. Turn off the phone.
    • 2. Press and hold the Volume Down and Power On buttons.
    • 3. When you feel a vibration, release only the Power On button.
    • 4. You will see on the screen an exclamation mark (!).
    • 5. Press the keys in this order: • Volume Up > Volume Down > Power > Volume Down •
    • The phone will restart.
    • Did you do it successfully?
    Didn’t work for me, I have the explanation mark, but as soon as I press the power button after vol up and dwn, it goes away and starts as usual.
    Simon Cusonnet - Responder
    then how did you do it?
    Arpanjot singh -
    I can see the exclamation symbol, but it shows only the exclamation symbol, no more
    Richyreaz - Responder
    it has worked sucessfully
    adams roland - Responder
    Worked well eventually. Note to self: read instructions CAREFULLY, but it worked after I read them properly!
    sue.edwards48 - Responder
    Yes it worked great. I did remove the sim and sd cards beforehand so as not to accidentally erase my saved data . Reinstalled them after startup and my phone is now back to functioning as I want it. Thanks for the hand.
    albert pruim - Responder
    Am going through the process well but once it reboots the blue screen with sad face re-appears
    robert gitende - Responder
    mine is asking for the protection recovery key
    coffi capello - Responder
    thanks its so helpful
    reason nhambura - Responder
    No,flight mode always on after hard resetting
    shavhani wa netshifhefhe - Responder
    Thanks very much.am sorted.Viva!
    Kipkemoi Kibiwott - Responder
    Super!!! Muchas gracias fue de mucha ayuda
    princesita696 - Responder
    Yes. Good. It worked very well. Thank you. Absolute result. Not even expected the process would be like this
    shiyaz khan - Responder
    Very Good Solution. Thank You.
    Lance Hildyard - Responder
    i did all the proccess but still its reserting its been a day now.please help
    mosime92 - Responder
    You guys are awesome. M making money out of this. Thank you so much for the hand.
    Brian Muuma - Responder
    excellent piece of advice worked like a dream
    kevin.pipefitter - Responder
    When mine vibrates and I hold down the volume down button it just restarts over and over again help plz
    Abs an a Am - Responder
    mine never worked it keeps restarting
    Caroline Darko - Responder
    my never worked and please is there anyway out that you can help me
    jedidiah - Responder
    flight mode remains on
    Gershom Bario - Responder
    Thanks. Worked perfectly.
    Tony Williams - Responder
    Thanks....works perfectly
    Dannie Chakholoma - Responder
Conclusão
This guide shows only how to erase the content of your phone.
62 outras pessoas executaram este guia.
ZFix
Membro desde: 12/09/13
191.308 Reputação
Autoria de 330 guias
Equipe
Master Techs Membro de Master Techs
Community
Membros da 322
Autoria de 2.534 guias
24 comentários
i have a challenge with my Lumia 520 i cant see the apps the screen is fine its difficult to format and everything in the phone is ok just that i cant use the phone its been given me issues and i have taken it for repairs they confirmed it needs to be flashed but i dont know what to flash it with as all the technicians i took it too couldn't flash the phone
godwing4 - Responder
Nokia Lumia 520 IMEI 358106054625804
Bawii Ali Sumail - Responder
Will this's reboot setting helps my Nokia 520 if the touch screen is lagging and i can only use my screen for certain things?
jessicaaa__014 - Responder
Hi my Nokia Lumia 520 is behaving weird lately,hanging most of the time ,touch not functioning well,.Recently it request me to do booting , what am i supposed to do?
Kizito. 28/5/2018
tobiaskizito -
What if my lumia 520 gets stuck on turning gears (reset mode)?
Sibusiso Dangazela - Responder
Gaand mein daal lena fir
catchprashantpandey -
hi Just to clear your doubt…Your nokia will never get stuck on the gears thing….maybe take a couple of hours…
Red hood Plays768 -
I have a password in my phone but the error is “try again in 164325 minutes“ so the only way is the hard reset, but my volume up were broken. What am i suppose to do? Is there any other way to fix this? Or I’ll just wait for that 123456 minutes to be over!?
Govan Cado - Responder
I'm having the same problem as yours. Have found ways to over come it. Please share. Thanks
saranjohl -
Successfully working
Kettie Sibanda - Responder
what if i can’t access other applications on my nokia 520? it can’t load application.
flshfit - Responder
my phone was switched off now when I switch it on its in airplane mode and it doesn't allow me to switch to 3G.
Mabu Molele - Responder
Comes ! exclamation sign but can't open?
Suranjan Chakravarty - Responder
It doesn't seem to be working for me but the phone is nearly dead and is on charge. Could that possibly be why?
Chi-Chi The Krazee Kat - Responder
after flashing my phone and follow the steps,when is time to bring out window symbol it off
oluwafemiidowu2018 - Responder
cool jais réussir a réinitialiser mon phone
koné gauthier - Responder
It works! Thank you very much!
chemiq81 - Responder
My lumia phone doesn’t recognize my sim card any more .Guidance please
MASINDE BOB - Responder
My Lumia 520 decided to stay offline mode and I can't access the link to boot it
jabulanisithole52 - Responder
what means RF inactive?
B N - Responder
Yeah it was very helpful. Thank you ?
thomas.osisco - Responder
funciono 2022 febrero 23 gracias
rulasromerobug - Responder
Yo le hice reset a mi Nokia Lumia 520, pero ya no encuentra las aplicaciones en la tienda de Microsoft, solo sirve para hacer llamadas. ;-)
luisangelveralopez70 - Responder
my nokia lumia is telling me to try again in15588 minutes please help
Boy Floyd Ratseane - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 18
Últimos 7 dias: 121
Últimos 30 dias: 605
Duração total: 241,392
