Ir para o conteúdo principal
How to Enable developer mode on Chromebook
    • Enabling or disabling developer mode will wipe your Chromebook. Your device will be Powerwashed, which means that any accounts and their files will be removed from the device. If you store your data online, then you can log on with the same account afterwards.
    • Officially Google does not offer support for developer mode since it is intended for developers. Enabling developer mode will void most warranty's, so if you encounter a hardware error, disable developer mode before getting warranty support.
    • To enable developer mode, you will need to deactivate OS verification. Only turn this on if you are sure of what you are doing!
    • On some older Chromebooks, Developer Mode could be turned on with a physical switch that could be flipped. However, on newer devices you will need to boot the device into Recovery Mode.
    • To start, make sure your Chromebook is on. Then press the Esc and Refresh keys and then press the power button.
    • Normally the refresh key is where the F3 key would be, and is normally the fourth key from the left on the top most row on a keyboard.
    • Your device should take you to a screen that says something along the lines of "Chrome OS is missing or damaged", signifying that you have arrived at the recovery screen.
    • Once you're at the recovery screen, press the Ctrl and D keys.
    • You'll see a screen that says " To turn OS verification OFF, press ENTER". Press enter to enable developer mode.
    • You will see a screen that indicates that OS verification is OFF. (If left long enough the device should beep at you.)
    • This screen is a security feature, as the developer mode doesn't have the usual security features. The screen is meant to help the normal user by guiding them through the process of disabling developer mode if they didn't mean to enable it.
    • To boot your device press the Ctrl and D keys again. Your device should boot automatically and will prepare your system for developer mode (This can take up to 15 minutes.
Conclusão
Congratulations! You now have full and unrestricted access to your Chromebook. If you wish to access a root shell press Ctrl, Alt, and the T keys to open the Crosh shell. From their type shell. You can use this to run commands with the sudo command to run commands with root access.
If you want to return to the standard mode, simply reboot your device and at the warning screen, simply press the space key as prompted. Your device will revet to the factory-default and will erase the files.
37 outras pessoas executaram este guia.
Jacob Mehnert
Membro desde: 10/18/21
45.585 Reputação
Autoria de 51 guias
Equipe
iFanatics Membro de iFanatics
Community
65 Membros
Autoria de 220 guias
8Comentários do guia
the divces owner had turned of developer mode how can i fix this fo
lenovo thinkpad e11 chromebook
Fadi Naddi - Responder
The process for disabling developer mode is very similar to enabling it. Turn off your device and turn it back on. When the Chromebook boots and displays the OS verification message, press the Spacebar. This will factory reset the device and return it to its standard configuration.
Jacob Mehnert -
Merci, pour le guide alor si cette manipulation (Esc et Refresh, puis appuyez sur le bouton d'alimentation) n'affiche pas l'écran de récupération. Que faire?
Divin - Responder
Selon l'âge de votre appareil, la combinaison de touches peut être différente. Sur certains modèles de Chromebook, vous devez appuyer sur les touches Échap et Agrandir et les maintenir enfoncées, puis appuyer sur Alimentation.
Jacob Mehnert -
What if the last Ctrl+D is not doing anything
Ava Lemburg - Responder
Comentar
Visualizações:
Últimas 24 horas: 62
Últimos 7 dias: 434
Últimos 30 dias: 1,946
Ao todo: 85,530
