Ir para o conteúdo principal
How to Dry and Preserve a Bouquet
O que você precisa
  1. How to Dry and Preserve a Bouquet, Prepare a bouquet: passo 1, imagem 1 %32
    • First and foremost, prepare a bouquet, which may come from your friends or parents as a present, or brought home from a grocery shopping trip. It is advisable to choose colorful flowers for better results.
  2. How to Dry and Preserve a Bouquet, Use scissors to cut each stem: passo 2, imagem 1 %32
    • Once you have the flowers, use scissors or cutters to cut each stem to expose a slanted surface, making each stem look like the sharp end of a straw.
  3. How to Dry and Preserve a Bouquet, Add supplements in the water: passo 3, imagem 1 %32
    • The purpose of the second step is made clear in the third step: the slanted surface maximizes the surface contact with water, making the flowers more durable and vibrant while you enjoy them in a water-filled vase.
    • Optionally, you may add supplements in the water, like flower food, to enhance the blossoms.
  4. How to Dry and Preserve a Bouquet, Wait several days and enjoy: passo 4, imagem 1 %32
    • After a few days on display, the flowers would reach their peak of liveness, which is also the best time to begin drying.
  5. How to Dry and Preserve a Bouquet, Use scissors to cut the tip of the petals: passo 5, imagem 1 %32
    • As the fifth step, use scissors to carefully cut the tip of the petals to create leveled planes for each blossom. If each petal were kept at a different length, the drying process would happen unevenly across different parts of the blossom.
  6. How to Dry and Preserve a Bouquet, Dry up the bouquet: passo 6, imagem 1 %32
    • In the sixth and most crucial step, use ropes or strings to tie the stems separately to a drying rack or cloth hangers upside-down. Place the rack or hangers at a ventilated place for it to naturally dry up in one or two weeks.
  7. How to Dry and Preserve a Bouquet, Put in a vase: passo 7, imagem 1 %32
    • At the ending of the drying process, the criteria for properly dried flowers are that the stems are hard like a wood branch and the petals are darker in color.
    • Finally, bundle all the flowers together to put in an empty vase that you like to enjoy for a long while.
Conclusão
Uma outra pessoa concluiu este guia.
Lisha Li
Membro desde: 09/17/21
445 Reputação
Autoria de 2 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 27
Ao todo: 427
