Ir para o conteúdo principal
How to Dry Wet Canon PowerShot SD850 IS Camera Components
Guia arquivado
Este guia é mantido exclusivamente para fins históricos. Use a versão atualizada do guia para executar o reparo.
O que você precisa
  1. How to Dry Wet Canon PowerShot SD850 IS Camera Components, Battery: passo 1, imagem 1 %32
    • Identify the battery port on the underside of the camera.
  2. How to Dry Wet Canon PowerShot SD850 IS Camera Components: passo 2, imagem 1 %32 How to Dry Wet Canon PowerShot SD850 IS Camera Components: passo 2, imagem 2 %32
    • Using your thumb, slide the port to the right and release.
  3. How to Dry Wet Canon PowerShot SD850 IS Camera Components: passo 3, imagem 1 %32
    • Remove the battery.
  4. How to Dry Wet Canon PowerShot SD850 IS Camera Components, Housing: passo 4, imagem 1 %32 How to Dry Wet Canon PowerShot SD850 IS Camera Components, Housing: passo 4, imagem 2 %32 How to Dry Wet Canon PowerShot SD850 IS Camera Components, Housing: passo 4, imagem 3 %32
    • To avoid severe electric shock do not remove or tamper with internal camera flash components. An electrical capacitor is attached to the flash that can discharge if contact is made.
    • Remove the two side screws, indicated by the red circles, using a Phillips #00 screwdriver.
    • Remove the screw in the battery port, indicated by the blue circle, again using a Phillips #00 screwdriver.
    • Remove the front face by gently peeling the housing away from the camera.
  5. How to Dry Wet Canon PowerShot SD850 IS Camera Components: passo 5, imagem 1 %32 How to Dry Wet Canon PowerShot SD850 IS Camera Components: passo 5, imagem 2 %32 How to Dry Wet Canon PowerShot SD850 IS Camera Components: passo 5, imagem 3 %32
    • Remove the back face by using a spudger to lift the tab highlighted in yellow
    • Pivot the back face clockwise as seen in the second photo.
  6. How to Dry Wet Canon PowerShot SD850 IS Camera Components: passo 6, imagem 1 %32 How to Dry Wet Canon PowerShot SD850 IS Camera Components: passo 6, imagem 2 %32
    • Remove the A/V port cover [no tools are necessary]
  7. How to Dry Wet Canon PowerShot SD850 IS Camera Components, How to Dry Wet Canon PowerShot SD850 IS Camera Components: passo 7, imagem 1 %32 How to Dry Wet Canon PowerShot SD850 IS Camera Components, How to Dry Wet Canon PowerShot SD850 IS Camera Components: passo 7, imagem 2 %32
    • Use compressed air to dry off camera's internal components.
    • Use caution when performing this step. Compressed air could possibly damage components if sprayed directly at connections or other sensitive areas.
Conclusão
iDeleted
Membro desde: 07/07/10
2.101 Reputação
Autoria de 39 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 2,481
