Introdução
This is a guide on how to descale an AGLUCKY HZB-12/H Countertop Ice Maker. Without regular cleaning, the ice machine will start to slow down and run inefficiently. Mineral build up will clog the machine and cause the sensors to stop working. This leads to the machine running with an empty reservoir and malfunctioning when trying to freeze ice.
O que você precisa
Turn off the icemaker by pressing the power button.
Remove the ice from the machine using the provided scoop.
Either discard the ice into your sink or put it in a separate container to use later.
We recommend repeating this descaling and cleaning process once every 2-6 months, depending on the hardness of water used in the machine.
4 outras pessoas executaram este guia.
4Comentários do guia
Any information on diagnosing technical issues with the unit not making ice?
Hi there! It looks like the owner's manual has a short troubleshooting section: https://images.thdstatic.com/catalog/pdf...
If you don't find success there, I'd recommend posing the question in our Answers forum, with a bit more detail describing your exact issue: https://www.ifixit.com/Answers/Ask
We hope that helps!
I misplaced my owners manual so I was very happy to find this how-to information. The pictures and instructions were great and suitable even for persons with language barriers. Thank you so much.
Can you use anything at home to clean it besides the solution you showed?
