Ir para o conteúdo principal
How to Darn a Sock
O que você precisa
  1. How to Darn a Sock, How to Darn a Sock: passo 1, imagem 1 %32 How to Darn a Sock, How to Darn a Sock: passo 1, imagem 2 %32
    • Insert a darning egg (or substitute object) into the sock until the hole is stretched out.
  2. How to Darn a Sock: passo 2, imagem 1 %32 How to Darn a Sock: passo 2, imagem 2 %32
    • Sew a running stitch around the hole to reinforce it.
    • To make a running stitch, move your needle in and out of the sock a fixed distance apart.
    • The needle is sharp; use caution and avoid poking your hand.
  3. How to Darn a Sock: passo 3, imagem 1 %32 How to Darn a Sock: passo 3, imagem 2 %32
    • Start a stitch from one side of the hole, about ½” to ⅛” away. Connect one side of the hole to the other using the thread.
    • Run parallel stitches until the hole is fully covered.
  4. How to Darn a Sock: passo 4, imagem 1 %32 How to Darn a Sock: passo 4, imagem 2 %32
    • Rotate your sock 90 degrees, then repeat step 4 to create a patch.
  5. How to Darn a Sock: passo 5, imagem 1 %32 How to Darn a Sock: passo 5, imagem 2 %32
    • Weave the extra thread into the sock's fabric, then cut the needle away from the thread.
Linha de Chegada
Uma outra pessoa concluiu este guia.
justinHo910
Membro desde: 10/24/23
145 Reputação
Autoria de 1 guia
Equipe
CSU Los Angeles, Team 1-1, Briggs Fall 2023 Membro de CSU Los Angeles, Team 1-1, Briggs Fall 2023
CSULA-BRIGGS-F23S1G1
6 Membros
Autoria de 5 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 67
Últimos 30 dias: 183
Ao todo: 823
