Ir para o conteúdo principal
How to Cover Up Ceiling Water Stains
O que você precisa
  1. How to Cover Up Ceiling Water Stains, How to Cover Up Ceiling Water Stains: passo 1, imagem 1 %32
    • Cover the area around the water stains with plastic sheets and tape.
  2. How to Cover Up Ceiling Water Stains: passo 2, imagem 1 %32 How to Cover Up Ceiling Water Stains: passo 2, imagem 2 %32
    • Wet a wipe with any bleach that you have in hand.
    • Clean the water-stained area with a bleach wipe.
    • This is an optional step.
  3. How to Cover Up Ceiling Water Stains: passo 3, imagem 1 %32 How to Cover Up Ceiling Water Stains: passo 3, imagem 2 %32
    • Apply the stain sealer to the area that was cleaned with wipes.
    • Be careful; this can stain anything.
  4. How to Cover Up Ceiling Water Stains: passo 4, imagem 1 %32
    • Once the stain sealer is applied, wait for it to dry.
  5. How to Cover Up Ceiling Water Stains: passo 5, imagem 1 %32
    • When the area is dry, remove the plastic.
Conclusão
To cover up your water stains at home, follow this easy guide.
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 35
Ao todo: 547
