Ir para o conteúdo principal
How to Cover Up Ceiling Water Stains
O que você precisa
  1. How to Cover Up Ceiling Water Stains, How to Cover Up Ceiling Water Stains: passo 1, imagem 1 %32
    • Cover the area around the water stains with plastic sheets and tape.
  2. How to Cover Up Ceiling Water Stains: passo 2, imagem 1 %32 How to Cover Up Ceiling Water Stains: passo 2, imagem 2 %32
    • Wet a wipe with any bleach that you have in hand.
    • Clean the water-stained area with a bleach wipe.
    • This is an optional step.
  3. How to Cover Up Ceiling Water Stains: passo 3, imagem 1 %32 How to Cover Up Ceiling Water Stains: passo 3, imagem 2 %32
    • Apply the stain sealer to the area that was cleaned with wipes.
    • Be careful; this can stain anything.
  4. How to Cover Up Ceiling Water Stains: passo 4, imagem 1 %32
    • Once the stain sealer is applied, wait for it to dry.
  5. How to Cover Up Ceiling Water Stains: passo 5, imagem 1 %32
    • When the area is dry, remove the plastic.
Conclusão
To cover up your water stains at home, follow this easy guide.
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 51
Duração total: 304
