Ir para o conteúdo principal
How to Clear a blocked, or clogged sink
  1. How to Clear a blocked, or clogged sink, How to Clear a blocked, or clogged sink: passo 1, imagem 1 %32
    • When you first go to clear your sink, you should check how the pipes are connected.
  2. How to Clear a blocked, or clogged sink: passo 2, imagem 1 %32
    • If your piping looks like the photo, you won't need tools to make this fix.
    • You can easily remove these pipes by twisting them off at the brackets.
  3. How to Clear a blocked, or clogged sink: passo 3, imagem 1 %32 How to Clear a blocked, or clogged sink: passo 3, imagem 2 %32
    • Twist the higher bracket until it comes undone.
  4. How to Clear a blocked, or clogged sink: passo 4, imagem 1 %32
    • Twist the lower bracket until it also comes undone.
    • Water and other liquids will pour out of the brackets so hold the pipe tightly to avoid making a mess.
  5. How to Clear a blocked, or clogged sink: passo 5, imagem 1 %32
    • Gently remove the pipe and find somewhere to dump out the contents that caused it to be clogged.
    • The pipe will be full of water and whatever is stuck inside. Any large obstructions or other blockages may fall out.
  6. How to Clear a blocked, or clogged sink: passo 6, imagem 1 %32
    • Clear out the gunk, obstructions, and any other objects in the pipe so that your sink drains properly.
  7. How to Clear a blocked, or clogged sink: passo 7, imagem 1 %32
    • Repeat the steps in reverse to put it back together again.
    • The blockage should now be removed and the sink should be draining properly.
Conclusão
Your sink should now be free of obstructions or clogs in the pipes.
4 outras pessoas executaram este guia.
Elijah Santiago
Membro desde: 09/18/15
196 Reputação
Autoria de 1 guia
Equipe
Um comentário
Smalll repairs can be done on a diy basis, but if drain clogging a regular problem the best solution would be to turn to professional pipe cleaning and restoration. i.e. pipe rehabilitation.
Kanserwis Sp. z o.o - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 25
Duração total: 1,717
