Ir para o conteúdo principal
How to Clean the Panasonic DVD-RV31 Player Laser
O que você precisa
  1. How to Clean the Panasonic DVD-RV31 Player Laser, Disk Tray Cover: passo 1, imagem 1 %32
    • Eject the disk tray from the DVD player before removing power supply.
  2. How to Clean the Panasonic DVD-RV31 Player Laser: passo 2, imagem 1 %32
    • Evenly lift upward on the disk tray front cover (not slanted, as pictured). This will allow for easier disassembly of the player.
  3. How to Clean the Panasonic DVD-RV31 Player Laser, Outer Case: passo 3, imagem 1 %32 How to Clean the Panasonic DVD-RV31 Player Laser, Outer Case: passo 3, imagem 2 %32
    • Remove the three screws running along the back edge of case cover.
    • Remove the two screws from each side of the case cover.
  4. How to Clean the Panasonic DVD-RV31 Player Laser: passo 4, imagem 1 %32
    • Grab edges of the cover with your hands. Pull outward slightly, then straight up.
  5. How to Clean the Panasonic DVD-RV31 Player Laser, Front Panel: passo 5, imagem 1 %32 How to Clean the Panasonic DVD-RV31 Player Laser, Front Panel: passo 5, imagem 2 %32
    • Lift up the five tabs securing the front panel to the chassis. There are three on the bottom, and two on the inside edges of the panel. Panel should then lift off the player.
  6. How to Clean the Panasonic DVD-RV31 Player Laser, Disk Drive: passo 6, imagem 1 %32 How to Clean the Panasonic DVD-RV31 Player Laser, Disk Drive: passo 6, imagem 2 %32 How to Clean the Panasonic DVD-RV31 Player Laser, Disk Drive: passo 6, imagem 3 %32
    • Locate the four screws securing the disk drive assembly. There are two on each side.
    • Use a narrow screwdriver to remove all four screws.
    • Remove the blue ribbon wire from its connector. When doing this, be cautious to not damage the connector.
  7. How to Clean the Panasonic DVD-RV31 Player Laser: passo 7, imagem 1 %32
    • Lift assembly by the front to pull metal bracket from the power board.
    • Pull up back end and lift drive out.
  8. How to Clean the Panasonic DVD-RV31 Player Laser: passo 8, imagem 1 %32
    • With the drive assembly separate from the player, hold as shown and pull the bracket edges away from the disk drive.
    • Lift bracket off and reserve for re-assembly.
  9. How to Clean the Panasonic DVD-RV31 Player Laser, Disc Retainer: passo 9, imagem 1 %32 How to Clean the Panasonic DVD-RV31 Player Laser, Disc Retainer: passo 9, imagem 2 %32 How to Clean the Panasonic DVD-RV31 Player Laser, Disc Retainer: passo 9, imagem 3 %32
    • Grasp the bridge above the wheel and push the tabs on the side as shown.
    • Pull down firmly and away from the laser housing.
  10. How to Clean the Panasonic DVD-RV31 Player Laser, How to Clean the Panasonic DVD-RV31 Player Laser: passo 10, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Microfiber Cleaning Cloths
    $3.99
    Comprar
    • Be sure to wash your hands before cleaning the optical laser lens.
    • Grab a microfiber or eyeglass cloth and gently brush the lens.
Conclusão
4 outras pessoas executaram este guia.
William
Membro desde: 04/26/11
283 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 18-20, Garner Spring 2011 Membro de Cal Poly, Team 18-20, Garner Spring 2011
CPSU-GARNER-S11S18G20
Membros da 4
Autoria de 11 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 41
Duração total: 7,455
