Ir para o conteúdo principal
How to Clean the Keurig K75 Platinum Brewing System Needle
O que você precisa
  1. How to Clean the Keurig K75 Platinum Brewing System Needle, How to Clean the Keurig K75 Platinum Brewing System Needle: passo 1, imagem 1 %32
    • Before needle repair, make sure the brewer is disconnected from any power outlet.
    • Lift the handle to open the top of the brewer.
    • There are two sharp needles that puncture the K-Cup pack. One is above the K-Cup holder and the other is in the bottom of the holder. Be careful when cleaning the top needle.
  2. How to Clean the Keurig K75 Platinum Brewing System Needle: passo 2, imagem 1 %32
    • Bend a paperclip to create a vertical metal piece. This is used to clean the top needle.
  3. How to Clean the Keurig K75 Platinum Brewing System Needle: passo 3, imagem 1 %32
    • Insert a paper clip into the exit needle to loosen the debris and push it out.
    • Repeat this action until the debris is cleared from the top needle.
    • All external pieces of the brewer are dishwasher safe.
Conclusão
Alexander Vo
Membro desde: 01/11/13
94 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 20-2, Maness Winter 2013 Membro de Cal Poly, Team 20-2, Maness Winter 2013
CPSU-MANESS-W13S20G2
Membros da 4
Autoria de 6 guias
9 comentários
must be something else on mine. i have cleaned out with paper clip 3 times and still no water comes out.
jjthdj - Responder
try descaling it
marymckercher -
Worked great for mine just now. I picked up a used B20 Platinum at a Garage Sale yesterday for only $10 super easy to clean needle & now it works great!! Thanks OP!!
ronald944 - Responder
My husband keeps wanting to buy me something new every time the old one doesn't work, well I am old fashioned and will do anything I can to save money. Thank goodness this worked than you so much.
Wendy Clark - Responder
How about the needle at the bottom of the holder?
tahoejb - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 26
Duração total: 21,891
