Ir para o conteúdo principal
How to Clean the Fan on a Toshiba TDP-XP2
O que você precisa
  1. How to Clean the Fan on a Toshiba TDP-XP2, How to Clean the Fan on a Toshiba TDP-XP2: passo 1, imagem 1 %32 How to Clean the Fan on a Toshiba TDP-XP2, How to Clean the Fan on a Toshiba TDP-XP2: passo 1, imagem 2 %32
    • Remove the two screws from the bottom plate as shown.
  2. How to Clean the Fan on a Toshiba TDP-XP2: passo 2, imagem 1 %32
    • Remove the two screws on the bulb housing.
  3. How to Clean the Fan on a Toshiba TDP-XP2: passo 3, imagem 1 %32
    • Pull the tab up and pull the bulb out vertically. Some force will be required, but it will come out.
  4. How to Clean the Fan on a Toshiba TDP-XP2: passo 4, imagem 1 %32
    • Using a can of compressed air, blow on the fan until all dust is gone.
    • Oil can be added in with a dropper on the bearing if needed.
Conclusão
Bryan Underwood
Membro desde: 04/02/18
697 Reputação
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 399
