Ir para o conteúdo principal
How to Clean and Maintain a Rogers Champion Plus Universal Remote Control 2125BC0-BX
O que você precisa
  1. How to Clean and Maintain a Rogers Champion Plus Universal Remote Control 2125BC0-BX, How to Clean and Maintain a Rogers Champion Plus Universal Remote Control 2125BC0-BX: passo 1, imagem 1 %32
    • Remove the battery cover and batteries from the remote.
  2. How to Clean and Maintain a Rogers Champion Plus Universal Remote Control 2125BC0-BX: passo 2, imagem 1 %32
    • Use a Phillips #00 screwdriver to remove the two 2 mm screws on the bottom of the remote.
  3. How to Clean and Maintain a Rogers Champion Plus Universal Remote Control 2125BC0-BX: passo 3, imagem 1 %32
    • Insert a spudger into one of the two cavities on the back of the remote.
    • Use the spudger to twist & pry until the seam of the remote separates.
    • Use gentle movements to pry the seam, as if handled improperly can result in damage.
  4. How to Clean and Maintain a Rogers Champion Plus Universal Remote Control 2125BC0-BX: passo 4, imagem 1 %32
    • Run a spudger along the seam of the remote to widen the space between the top & bottom halves of the remote.
    • Press firmly into the seam and listen for a popping sound, which indicate the seams have separated.
    • Repeat for both sides of the remote.
    • Return to the back of the remote and use the spudger to pop the remote open.
  5. How to Clean and Maintain a Rogers Champion Plus Universal Remote Control 2125BC0-BX: passo 5, imagem 1 %32
    • Remove the rubber number pad and the plastic divider below to reveal the circuit board.
    • Use a cotton swab soaked in rubbing alcohol to clean the exposed circuit board.
    • Try to clean using circular motions. Also, you can clean the affected area directly and not necessarily the whole board.
  6. How to Clean and Maintain a Rogers Champion Plus Universal Remote Control 2125BC0-BX: passo 6, imagem 1 %32
    • Clean the rubber number pad by dipping the toothbrush in rubbing alcohol and gently scrubing the back of the rubber keypad.
  7. How to Clean and Maintain a Rogers Champion Plus Universal Remote Control 2125BC0-BX: passo 7, imagem 1 %32
    • If you need to replace the circuit board for any reason, it comes off by hand like the other components in this model of remote.
Conclusão
Repeat the steps backwards to reassemble device.
Mohamad Mohamad
Membro desde: 01/18/21
436 Reputação
Autoria de 3 guias
Equipe
York University, Team M-6, Allen Summer 2023 Membro de York University, Team M-6, Allen Summer 2023
YORK-ALLEN-SU23SMG6
Membros da 3
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 16
Duração total: 640
