Ir para o conteúdo principal
How to Clean and Apply Thermal Compound
O que você precisa
  1. How to Clean and Apply Thermal Compound, How to Clean and Apply Thermal Compound: passo 1, imagem 1 %32
    • Saturate a cotton swab with isopropyl alcohol, and remove the thermal compound from the thermal plates on your component using gentle circular motions.
    • As the cotton swab becomes saturated with thermal compound, discard and continue with a freshly dipped cotton swab. The compound plate is clean when the cotton swabs come away clean.
  2. How to Clean and Apply Thermal Compound: passo 2, imagem 1 %32 How to Clean and Apply Thermal Compound: passo 2, imagem 2 %32
    • Repeat the same cleaning process from the previous step on the matching thermal plates on the motherboard.
    • Avoid touching the thermal compound areas once they are clean. Dirt or oil on either surface can disrupt cooling performance and lead to overheating or thermal throttling.
  3. How to Clean and Apply Thermal Compound: passo 3, imagem 1 %32 How to Clean and Apply Thermal Compound: passo 3, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Plastic Cards
    $2.99
    Comprar
    • Apply a small amount of thermal compound, about the size of a grain of rice, on the corner of each the cleaned thermal plates on the motherboard.
    • Using a clean plastic card, carefully spread the thermal compound evenly over the surfaces of each thermal plate.
    • You need to clean the thermal plates on both the component and the motherboard, but you only need to apply thermal paste on the motherboard thermal plates.
    • Avoid applying too much or too little thermal compound, as it can impede crucial heat transfer. Once spread, the compound should be about as thick as a single sheet of paper.
  4. How to Clean and Apply Thermal Compound: passo 4, imagem 1 %32
    • Gently re-seat your component, making sure that the thermal plates align correctly.
Conclusão
Please refer to the previous guide in order to reassemble your device.
4 outras pessoas executaram este guia.
Reina Godeck
Membro desde: 10/16/17
741 Reputação
Autoria de 5 guias
Equipe
UW Tacoma, Team S3-G5, Liner Fall 2017 Membro de UW Tacoma, Team S3-G5, Liner Fall 2017
UWT-LINER-F17S3G5
Membros da 4
Autoria de 18 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 13
Duração total: 2,231
