Ir para o conteúdo principal
How to Clean an LG Goldstar BG5200ER Air Conditioner Air Filter
O que você precisa
  1. How to Clean an LG Goldstar BG5200ER Air Conditioner Air Filter, How to Clean an LG Goldstar BG5200ER Air Conditioner Air Filter: passo 1, imagem 1 %32 How to Clean an LG Goldstar BG5200ER Air Conditioner Air Filter, How to Clean an LG Goldstar BG5200ER Air Conditioner Air Filter: passo 1, imagem 2 %32
    • Turn off the air conditioner unit manually or with the remote control.
    • Unplug the A/C unit from its power source.
  2. How to Clean an LG Goldstar BG5200ER Air Conditioner Air Filter: passo 2, imagem 1 %32 How to Clean an LG Goldstar BG5200ER Air Conditioner Air Filter: passo 2, imagem 2 %32
    • Place your hands on the opposite sides of the air conditioner and unclip the grille from the unit.
  3. How to Clean an LG Goldstar BG5200ER Air Conditioner Air Filter: passo 3, imagem 1 %32 How to Clean an LG Goldstar BG5200ER Air Conditioner Air Filter: passo 3, imagem 2 %32 How to Clean an LG Goldstar BG5200ER Air Conditioner Air Filter: passo 3, imagem 3 %32
    • Gently grab the front grille and place it on the ground or table.
    • Use your hands to pull the filter out of the unit
  4. How to Clean an LG Goldstar BG5200ER Air Conditioner Air Filter: passo 4, imagem 1 %32 How to Clean an LG Goldstar BG5200ER Air Conditioner Air Filter: passo 4, imagem 2 %32
    • Carry the filter to a faucet and flush with water to eliminate dust particles.
    • Lay down the clean air filter on a towel until it's completely dry.
    • The filter will take about five to eight minutes to dry.
    • Do not place a wet filter back into the unit. Placing a damp filter in the unit can cause water damage to the air conditioner.
  5. How to Clean an LG Goldstar BG5200ER Air Conditioner Air Filter: passo 5, imagem 1 %32 How to Clean an LG Goldstar BG5200ER Air Conditioner Air Filter: passo 5, imagem 2 %32 How to Clean an LG Goldstar BG5200ER Air Conditioner Air Filter: passo 5, imagem 3 %32
    • Replace the air filter between the front grille and evaporated coil.
    • Clip the front grille back to the unit and push the grille to align the sides with the clips.
Conclusão
To reassemble the air conditioner, replug the A/C unit cord to the power outlet and turn it on.
Angel R. Mariscal
Membro desde: 03/24/22
145 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 12
Últimos 30 dias: 51
Duração total: 1,219
