Ir para o conteúdo principal
How to Clean a Mainstays Coffee Maker Water Tube
O que você precisa
  1. How to Clean a Mainstays Coffee Maker Water Tube, How to Clean a Mainstays Coffee Maker Water Tube: passo 1, imagem 1 %32 How to Clean a Mainstays Coffee Maker Water Tube, How to Clean a Mainstays Coffee Maker Water Tube: passo 1, imagem 2 %32 How to Clean a Mainstays Coffee Maker Water Tube, How to Clean a Mainstays Coffee Maker Water Tube: passo 1, imagem 3 %32
    • Open the top of the coffee maker.
  2. How to Clean a Mainstays Coffee Maker Water Tube: passo 2, imagem 1 %32 How to Clean a Mainstays Coffee Maker Water Tube: passo 2, imagem 2 %32
    • Use a Phillips screwdriver to remove the four 6 mm screws surrounding the puncturing needle.
  3. How to Clean a Mainstays Coffee Maker Water Tube: passo 3, imagem 1 %32 How to Clean a Mainstays Coffee Maker Water Tube: passo 3, imagem 2 %32 How to Clean a Mainstays Coffee Maker Water Tube: passo 3, imagem 3 %32
    • Press down on the brew chamber release button and remove the backing piece.
  4. How to Clean a Mainstays Coffee Maker Water Tube: passo 4, imagem 1 %32 How to Clean a Mainstays Coffee Maker Water Tube: passo 4, imagem 2 %32 How to Clean a Mainstays Coffee Maker Water Tube: passo 4, imagem 3 %32
    • Disconnect the water tube from where it is connected to the needle.
  5. How to Clean a Mainstays Coffee Maker Water Tube: passo 5, imagem 1 %32 How to Clean a Mainstays Coffee Maker Water Tube: passo 5, imagem 2 %32 How to Clean a Mainstays Coffee Maker Water Tube: passo 5, imagem 3 %32
    • Flip the coffee maker upside down.
  6. How to Clean a Mainstays Coffee Maker Water Tube: passo 6, imagem 1 %32 How to Clean a Mainstays Coffee Maker Water Tube: passo 6, imagem 2 %32
    • Use a Phillips screwdriver to remove the four 7 mm screws on the base of the coffee maker.
  7. How to Clean a Mainstays Coffee Maker Water Tube: passo 7, imagem 1 %32 How to Clean a Mainstays Coffee Maker Water Tube: passo 7, imagem 2 %32 How to Clean a Mainstays Coffee Maker Water Tube: passo 7, imagem 3 %32
    • Remove the base.
  8. How to Clean a Mainstays Coffee Maker Water Tube: passo 8, imagem 1 %32 How to Clean a Mainstays Coffee Maker Water Tube: passo 8, imagem 2 %32
    • Use an 8" Phillips screwdriver to remove the five internal 14 mm screws from within the coffee maker.
    • Use an 8" Phillips screwdriver to remove the six internal 7 mm screws from within the coffee maker.
    • The second image shows the approximate placement of the screws; you may have to reach inside and move wires to locate and access all eleven screws.
  9. How to Clean a Mainstays Coffee Maker Water Tube: passo 9, imagem 1 %32 How to Clean a Mainstays Coffee Maker Water Tube: passo 9, imagem 2 %32 How to Clean a Mainstays Coffee Maker Water Tube: passo 9, imagem 3 %32
    • Flip the coffee maker right-side up.
  10. How to Clean a Mainstays Coffee Maker Water Tube: passo 10, imagem 1 %32 How to Clean a Mainstays Coffee Maker Water Tube: passo 10, imagem 2 %32 How to Clean a Mainstays Coffee Maker Water Tube: passo 10, imagem 3 %32
    • Pull the disconnected end of the water tube out of the top of the coffee maker.
  11. How to Clean a Mainstays Coffee Maker Water Tube: passo 11, imagem 1 %32
    • Move the top of the coffee maker out of the way so that you can reach into the base.
    • You may wish to put something under the top to support it.
  12. How to Clean a Mainstays Coffee Maker Water Tube: passo 12, imagem 1 %32 How to Clean a Mainstays Coffee Maker Water Tube: passo 12, imagem 2 %32 How to Clean a Mainstays Coffee Maker Water Tube: passo 12, imagem 3 %32
    • Identify where the water tube is connected at the other end.
    • Use pliers or your hand to disconnect it.
    • If you choose to use pliers, take caution not to puncture the tube.
  13. How to Clean a Mainstays Coffee Maker Water Tube: passo 13, imagem 1 %32 How to Clean a Mainstays Coffee Maker Water Tube: passo 13, imagem 2 %32 How to Clean a Mainstays Coffee Maker Water Tube: passo 13, imagem 3 %32
    • Locate any blockages in the water tube and use your chosen tool (chenille stick, wooden dowel, toothpick, etc.) to push them out.
    • If the tube looks cloudy, use a chenille stick to break up the buildup.
  14. How to Clean a Mainstays Coffee Maker Water Tube: passo 14, imagem 1 %32
    • Rinse any remaining debris out of the tube.
    • Depending on what tool you chose to use in the previous step, particles from said tool may need to be rinsed out as well.
Conclusão
Lorelei Kriss
Membro desde: 01/30/24
229 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team 4-9, Andersen Winter 2024 Membro de UC Davis, Team 4-9, Andersen Winter 2024
UCD-ANDERSEN-W24S4G9
Membros da 2
1 Guia de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 29
Duração total: 208
