Ir para o conteúdo principal
How to Clean a Kitchen Aerator
O que você precisa
  1. How to Clean a Kitchen Aerator, How to Clean a Kitchen Aerator: passo 1, imagem 1 %32 How to Clean a Kitchen Aerator, How to Clean a Kitchen Aerator: passo 1, imagem 2 %32
    • Shut off valves that are located under the sink and position faucet in the center to drain remaining water.
  2. How to Clean a Kitchen Aerator: passo 2, imagem 1 %32
    • Avoid dropping small parts down the sink by covering the surface of the holes.
  3. How to Clean a Kitchen Aerator: passo 3, imagem 1 %32
    • Unscrew and remove aerator with a wrench.
  4. How to Clean a Kitchen Aerator: passo 4, imagem 1 %32
    • Clean aerator by soaking it in white vinegar overnight in a bowl or cup.
  5. How to Clean a Kitchen Aerator: passo 5, imagem 1 %32
    • Dry off aerator with a towel.
  6. How to Clean a Kitchen Aerator: passo 6, imagem 1 %32
    • Use a wrench to screw back on the aerator to the faucet.
  7. How to Clean a Kitchen Aerator: passo 7, imagem 1 %32
    • Slowly turn back on water valves to check for improves water pressure.
    • Make sure sink is cleared and components of faucet that were removed are sealed tight.
Conclusão
Uma outra pessoa concluiu este guia.
Amber Cuddon
Membro desde: 01/20/18
181 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 22
Últimos 30 dias: 65
Ao todo: 1,664
