Ir para o conteúdo principal
How to Clean a Kenmore 70101 Wall/Window AC Filter
O que você precisa
  1. How to Clean a Kenmore 70101 Wall/Window AC Filter, How to Clean a Kenmore 70101 Wall/Window AC Filter: passo 1, imagem 1 %32 How to Clean a Kenmore 70101 Wall/Window AC Filter, How to Clean a Kenmore 70101 Wall/Window AC Filter: passo 1, imagem 2 %32
    • Open the front grille of the AC.
  2. How to Clean a Kenmore 70101 Wall/Window AC Filter: passo 2, imagem 1 %32 How to Clean a Kenmore 70101 Wall/Window AC Filter: passo 2, imagem 2 %32
    • Unsnap or unclip the filter from its mount and lift it from the slot.
  3. How to Clean a Kenmore 70101 Wall/Window AC Filter: passo 3, imagem 1 %32 How to Clean a Kenmore 70101 Wall/Window AC Filter: passo 3, imagem 2 %32
    • Thoroughly wash the filter's panels with water and a mild soap or dishwashing liquid.
    • Completely rinse the soap from the filter's surface.
  4. How to Clean a Kenmore 70101 Wall/Window AC Filter: passo 4, imagem 1 %32 How to Clean a Kenmore 70101 Wall/Window AC Filter: passo 4, imagem 2 %32
    • Dab the filter with a soft towel to remove most of the water, then allow time for the filter to completely air dry.
    • Return the filter to its original place behind the AC's front grille.
  5. How to Clean a Kenmore 70101 Wall/Window AC Filter: passo 5, imagem 1 %32 How to Clean a Kenmore 70101 Wall/Window AC Filter: passo 5, imagem 2 %32
    • Firmly close the front grille.
Conclusão
Cleaning your AC's filter is fast, easy, and more cost-efficient than buying an entirely new one. Enjoy the cool air!
Uma outra pessoa concluiu este guia.
Vashante Johnson
Membro desde: 10/27/22
145 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 23
Últimos 7 dias: 102
Últimos 30 dias: 377
Duração total: 2,783
